LackyLo
Posted: Sun Dec 14, 2008 12:07 pm Post subject: Service manual NAD 3220PE amplivier |
Hello
Can anyone help me with a service manual or electric circed diagram for an NAD 3220PE amplivier? Need it for finding out the value from 2 burned resitances.
Thanks and good times for you all |
Posted: Sun Dec 14, 2008 5:18 pm Post subject: Re: Service manual NAD 3220PE amplivier |
LackyLo wrote: | Hello
I think there were some similarity between those units....I have a 3225PE/3020I Perhaps it just may be similar to what you have?
What resistors are you looking for on what circuit? |
LackyLo
Posted: Mon Dec 15, 2008 7:54 pm Post subject: NAD 3220PE |
Thanks for your try to help me!
Seems the driver circuit for the power trans
driver trans BD 139 collector resistor and trans 2SD669A emiter resitor...
pehaps you have an idea?
greetings LackyLo |
Posted: Tue Dec 16, 2008 5:19 pm Post subject: |
There are two BD139's one of which seems to be on a heatsink Q409
here's the final stage.---(Btw, you may want to check all the surrounding components as there may be others).
XXX1 Guest
Posted: Wed Dec 17, 2008 4:25 pm Post subject: NAD amp |
Thank You so much!!!
That was exact what I needed.
Greetings from Vienna LackyLo
P.S. So great that there is an internet.... |
Danrey Guest
Posted: Sun Jan 03, 2010 8:20 pm Post subject: NAD 3225pe cap c511 needed |
I have a NAD 3225pe and have the c511 burned (between the two main big caps ) do you have the circuit for that one? Need to know the size
Thanks,
Dan |
Posted: Mon Jan 04, 2010 4:00 am Post subject: Re: NAD 3225pe cap c511 needed |
Danrey wrote: | Hi,
Thanks,
Dan |
Same as C510, C512 .1 microfarad 50 V. (not critical for type, you can use ceramic, polypropylene etc)
Danrey Guest
Posted: Wed Jan 06, 2010 4:53 am Post subject: This is exactly my problem |
That's it
Now I replaced the cap but noticed the 4 fuses were blown, replaced them and still the ones going to the 8 ohms blew again.
where could the problem be? I measured the diodes andd seem ok.
What else should I do and measure? |
Posted: Thu Jan 07, 2010 10:45 pm Post subject: |
Sounds like there is still a load on the supply line and if the diodes check Ok and there are no problem with diodes or electrolytics, more than likely you have blown outputs; Q415/416 Q417/418 &/or predrivers Q411thru414-- possibly more? |
