gat1954
Posted: Sat Dec 27, 2008 11:17 pm Post subject: mitsubishi CS35401 35" TV horizontal |
I had a Problem with Vertical Hold... then Replaced that Chip...and Now all I get is White Screen/ Purple,, with some Horizontal Lines..
with NO picture,,, from the Tuner,,,, Sound is OK... and channels switch,,but no Picture.. Seems whitish purple...
I noticed the Repair Tech,, Cracked The Little Yoke Circuit Board.. where It attaches to the back of the TUBE... So I repaired it... made sure the three copper joints were making contacts, properly/...
and I still get the same Problem... Whitish Purple...
Could anybody help Please,,,
Service manual for CS-3540 1993 35 incher.. _________________ CS-35401 Mitsubushi |
Posted: Sun Dec 28, 2008 1:05 am Post subject: Re: Mitsubishi |
Slow down... What is model number: CS-3540 OR CS35401? Also What "that chip?" You seem to be omitting some part of your story? "Cracked The Little Yoke Circuit Board" ... I'll assume you mean CRT socket board. |
gat1954
Posted: Sun Dec 28, 2008 4:06 am Post subject: |
The Vertical Chip...LA--7838 VERTICAL HOLD Chip... on the main Board..
The TV is a Mitshubushi 35401 35 inch Tube
YES... teh CRT Socket Board,,, had a minor Crack from somebody bending a Heatsink ... 45 degrees.. SoI repaired those Lines... _________________ CS-35401 Mitsubushi |
Posted: Sun Dec 28, 2008 4:52 am Post subject: Re: Mitsubishi |
When set had "Vert Hold" problem (Picture/Screen ROLLING?), could you make out any video?
LA7838 is Vertical deflection I.C., but even with NO sweep (horizontal line), you should still have been able to make out whether video was present. |
gat1954
Posted: Sun Dec 28, 2008 5:34 am Post subject: |
Yes...there was Video..... before that Chip went in..... I suspect, that either the crack CRT Circuit Board... I didn't notice it right away,, as I plug it in,,,, and the Video never returned... But I tried to repair Where the cracks were on the Board,, to make continuity that with my Weller Pencil Solder
or something The Tech might have done in his soldering on the main Board _________________ CS-35401 Mitsubushi |
Posted: Sun Dec 28, 2008 5:43 am Post subject: Re: Mitsubishi |
Does CRT board have any gun cut off / service switches? Note position, work switch, look for improvement. Examine board with magnification. Easy to miss one foil break. |
gat1954
Posted: Sun Dec 28, 2008 6:39 am Post subject: |
Yes the CRT has Two Switches on both sides of the Circuit Board...
sort of a Lateral switch, that moves in multitude of dimensions...
I paused,,,,and Found Two more tiny FOIL BREAKS
I do have a Headset Magnifer,,, to greatly check them... IT
doesn't take much ..
WOULD this be enough to cause the Problem >??? of what were talking about here.. _________________ CS-35401 Mitsubushi |
gat1954
Posted: Sun Dec 28, 2008 7:24 am Post subject: |
OK.... I found three More Foil Breaks,,, Soldered them , and tested for continuity... ... Fired it up..... I get a SOLID BLUE screen...
Now I connect the cable,,, and I get sound,,, but a Black,,screen,,,
when I go to channel,, that isn't on the Line up... like 21,,it reverts to solid blue....
WERE Getting Closer..... it's 11:30 PM here in San diego California..
maybe I can see you tomorrow... [email protected]
over and out.. _________________ CS-35401 Mitsubushi |
