piks Guest
Posted: Wed Jun 01, 2005 2:36 am Post subject: there is a discoloration on my tv, near the speakers. |
Any reason or suggestions will be appreciated |
Brian Guest
Posted: Wed Jun 01, 2005 5:49 am Post subject: Discolouration on T/V screan. |
The discolouration is caused by the magnetic field from your speaker magnets, move the speakers at least 2 to 3 feet away from the T/V. That will cure your (purity) you call discolouration on your T/V. You may have to use a degaussing wand which gives you a magnetic field to wave in front of the T/V to permently cure your purity problem. I do hope this answer helps you, your friend Brian Luck. |
melw Guest
Posted: Wed Jun 01, 2005 6:43 pm Post subject: Degausse |
Actually, every color TV has a built in degaussing circuit which activates each time the TV is turned on. You do not need an external degausing coil. |
Posted: Wed Jun 15, 2005 9:44 am Post subject: |
Not true. Any external magnetism can override the degaussing circuit and in particular the ptc or ntc. A faulty positor will no longer degauss and any Purity patch present for longer than six months can become a permanent fixture regardless of an inbuilt degaussing circuit. |
Posted: Wed Jun 15, 2005 9:46 am Post subject: |
Posted: Wed Jun 15, 2005 9:50 am Post subject: |
The degaussing wand will also remove any residue magnetism that the degauss circuit is unable to. |
Posted: Sun Jul 10, 2005 7:01 am Post subject: |
You are supposed to use shielded speakers near your television!!! |
