davidk111
Joined: 23 Jan 2009 Posts: 3 Location: So far away you can't wrap your head around it.
Posted: Fri Jan 23, 2009 1:57 am Post subject: hitachi ultravision 50ux23k convergence |
My set has the blue out of wack. Every now and then it does correct itself for 30 min up to several hours. Magic focus does not do anything to correct. I read on this post http://forum.eserviceinfo.com/viewtopic.php?p=86697 some very helpfull info from minnie but would like to know if my set uses the same parts as it is a 50ux23k not a 50ux23ka.
Also, I went to the parts site listed in the other post but need some more info. does the IK04/05/06 refer to the slots where the convergence amps go? In other woods, does the convergence amp model STK4274 work in each slot or do you need to order 3 different models of amps, Model STK4274 IK04, Model IK05 and Model IK06 because I only found STK4274 on the site.
One more thing please, I read on another site that convergence amps that cost less then $30-$40 bucks apiece are cheap knockoffs and will go bad in a month or two. This is coming from tv repair people though so not sure if it's BS or not. Any feedback on this?
Thanks in advance for and help!
David |
Posted: Fri Jan 23, 2009 11:16 am Post subject: |
Reread the thread. Models should be in same Family. IKxx is the "location" of each I.C. (or as you refer to them "slots"). You'll need one IC for each location/slot. Minnie's right, if one is bad, rest are suspect. |
davidk111
Posted: Sat Jan 24, 2009 12:57 am Post subject: |
Thanks for the reply. I'm still not sure if the IC listed in the other post would work in my set though as mine is a slightly different model number. |
Posted: Sat Jan 24, 2009 3:14 am Post subject: Re: Conv. I.C.s |
OK - So your model number does not match one in post EXACTLY.
Do the Location numbers & the Numbers on the IC's match what was in the post (STK4274)? If so, models are close enough.
IK04 = STK4274
IK05 = STK4274
IK06 = STK4274 |
Posted: Sat Jan 24, 2009 4:35 am Post subject: can you help me minnie????? |
thanks for the post. does not help but thanks for the reply. The TV works as is but I have no reason to tear into it right now to inspect the board until I have a game plan. I hope for a more informed answer. Waiting for minnie as I have seen he/she is more foregiving as far as walking folks through things. |
davidk111
Posted: Sat Jan 24, 2009 5:18 am Post subject: |
Your first reply to my post and 2nd WAS a bit rude if your not a elec tech as you must be. Take yourself back to when you did not know next to nothing about this field and tried to train a new hire on the basics.
I really can use your help but please don't talk down to me. Just read what I post and respond with info thats helps, not c&^%. (I know it's hard, I am a math wiz and get sooooo bent out of shape when my daughter who is 8 can't do simple X problems) |
Posted: Mon Jan 26, 2009 9:39 pm Post subject: |
STK4274
Wow, this is an oldie. 3 STK4274 would be correct. |
