Xtech Guest
Posted: Wed Feb 04, 2009 5:10 am Post subject: Spectroniq PLTV-3250 wont start |
Hello
I am working with a spectroniq (proton) model PLTV-3250
LCD TV. The set will not start I found a series of bad electrolytic
capacitors in the power supply along with a small
surface mount transistor, all of which I have replaced.
The front standby light is not lit. It uses an FSP194-3F01 power supply.
I have not been able to round up any service data for this unit.
And they dont appear to have a website anywhere on the net.
I need to know at what points in the supply I should be receiving
voltage and how much. There is a noise that's barely audible coming
from the top area of the set, I think its one of the boards that control
the LCD panel lights, but I'm not 100 percent sure.
Just curious if anyone has (or knows) where I can get a manual,
and help steer me in the right direction.
Thank you |
Posted: Wed Feb 04, 2009 5:51 am Post subject: |
Only thing I know that it was not made by Proton---it was Protron Digital which filed for chapter 11 on 08. No idea about the manual though? |
Xtech Guest
Posted: Wed Feb 04, 2009 4:36 pm Post subject: |
I sent an Email to FSP (the manufacturer of the power supply)
and requested a schematic. I’ll see how cooperative they are. |
Xtech Guest
Posted: Tue Feb 17, 2009 10:19 pm Post subject: |
Update:
The company who makes the supply wouldn't supply a schematic.
I found a new power supply and replaced it. |
hacker gnome Guest
Posted: Fri Feb 20, 2009 5:25 am Post subject: FSP194-3F01 |
xtech, Where did you find a power supply?
Thanks |
Xtech Guest
Posted: Tue Feb 24, 2009 11:16 pm Post subject: Re: FSP194-3F01 |
hacker gnome wrote: | xtech, Where did you find a power supply?
Thanks |
Ebay,
I was able to repair the old one.
After doing some comparison testing between the
two. I found a zener diode that was killing the 5 volt
standby voltage. It was neither shorted or open. It
originally tested good in circuit using diode check on my DMM. |
[email protected] Guest
Posted: Thu Dec 09, 2010 9:06 pm Post subject: 5 volts stand by missing |
i have work in this tv proton for several times and i never hane any problem with the 5 volts stand by but always found a cap bad on 5 stby after replaced the caps if any vary has still problems with 5 volts stby chek ZD4 its close to the IC2its reading bad after you replaced this zener diode power will work 5 volts stand by missing |
nowone Guest
Posted: Wed Jan 19, 2011 12:16 pm Post subject: zener |
What is the voltage for the zener diode? |
TA8637BP Toshiba • MZ-NE410 Sony • 31GT720 RCA • Allocchio Bacchini 521 531 534 ALLOCCHIO • 832B EMERSON • smg2301p Secos • bf996s 1 Philips • CCE+DVD-2940D CCE • 09 PCB Diagram Samsung • 2sc5993 Inchange Semiconductor •
