ivtec
Posted: Mon Feb 23, 2009 3:24 am Post subject: IR remote extenders not working anybody has a clue? |
Hi i bought tow these wireless remote control extenders and i plugged it to my satellite but can't make it work, i do like per instructions but nothing, what am i doing wrong any help would be appreciated i tried all the ways but no avail.thanks in advance.
[url=http://www.gosatellite.com/Remote-Li...k-extender.htm]GOSatellite.com |
ivtec
Posted: Tue Feb 24, 2009 2:19 am Post subject: Re: IR remote extenders not working anybody has a clue? |
ivtec wrote: | Hi i bought tow these wireless remote control extenders and i plugged it to my satellite but can't make it work, i do like per instructions but nothing, what am i doing wrong any help would be appreciated i tried all the ways but no avail.thanks in advance.
i have here some specs about these IR extenders
do i need DC spliters or dc blockers?
Modulation FSK
Deviation 5khz
center freq. 27.045mghz/27.145mghz
data rate 5kbps
IR emitting freq. 38Khz
IR EXTENDER RECEIVER
Sensivity 90dbm
insertion loss 1.5db ,@ 860MHZ/[email protected]
IF Frequency Current consumption 20 ma typ.
IR Emitting range 5m typ.
IR Extender
Output power -15bm
insertion loss 3db@ 860MHZ
L.O Leakage to tv port 80dbm
current consumption 10mA typ. |
Posted: Fri Feb 27, 2009 9:22 am Post subject: |
Are you sure that your satellite receiver's remote control uses just 38 kHz as modulation frequency? Although that is a very common frequency, it is not the only one used. Be prepared to find just about any frequency from 30 to 56 kHz.
Another possibility is if the IR receiver is being blocked by light from, for example a low energy lamp, fluorescent lamp or LED lamp using a high frequency driver.
Do the IR extenders have their own power supply or do they rely on a DC supply via the cable? I see that they use a relative low frequency of 27 MHz, are you sure that there are no filters, splitters, amplifiers etc in the cable that might act as high-pass filters causing high loss at that low frequency? |
ivtec
Posted: Wed Mar 04, 2009 12:05 am Post subject: |
torbjorn wrote: | Are you sure that your satellite receiver's remote control uses just 38 kHz as modulation frequency? Although that is a very common frequency, it is not the only one used. Be prepared to find just about any frequency from 30 to 56 kHz.
Thanks for helping I 've got this IR working , i gues it doesn't like amps and regular spliters, i'm yet to check with dc passive spliters,i connected strait to a tv alone and had to twick around with the receiverI IR in front of the receiver,it doesn't like to be too close or to separated apart,it was hard to put this thing to work but i got it. |
EL6436 Philips • HT-BD2.part2 Samsung • 25-6007-0 Electric Typewriters CE Ref Ma • kmb012n30q KEC • 68117-WW-1 MAKITA • ve pl-5 420 service Pioneer • HP 4271A Operating Agilent • lc9.2lla 480672717383 32pfl5604d 42pfl56 • Panel CMO M190A1-L09 1 [DS] . Various • TX-28LD7C Panasonic •
