on4aah
Posted: Wed Mar 04, 2009 2:30 pm Post subject: DAEWOO KOC995T |
Warms no longer , all the rest works yet, replace transistor relaisdrive wave. |
Posted: Wed Mar 04, 2009 9:48 pm Post subject: |
Does the relay energize when "Start" is pressed?
Be careful - high voltage & currents may be present!
The most common things that can cause "No Heat" in microwave ovens:
Bad solder joints (especially at relays pins, plug in connector pins, etc.) on the control board;
Burnt/corroded/loose plug in connections anywhere in the oven;
Defective Door / Safety Interlock switches. |
on4aah
Posted: Thu Mar 05, 2009 8:27 pm Post subject: |
Hello
The microwave work sometimes in the 'Hi' position and not in the 10 to 90 position.In the position 10 to 90 switch te waverelais on and off three or four times on 60 sec, but the wave power worked not good,the relais was OK, but the transistor worked not good,replace and everything back OK.
Greetings |
VSX-916 Pioneer • std50nh02l ST • fdb2614 Fairchild Semiconductor • trouble EP2050 052 Minolta • PANASONIC TX-L26C10P Ch .GLP24.part4 p • XXl distortion Tech21 NYC • 2sc2582 Inchange Semiconductor • manualst Philips • 19780613 Graphical Bar Chart Examples xe • TARW99 Onkyo •
