les_garten
Posted: Wed Mar 04, 2009 8:17 pm Post subject: Kenwood DV-5900M Help Needed |
Hello,
I have Kenwood DV-5900M, that has not been used for a long time. I pulled it out to set it up and it goes to D001 T01 on startup and does nothing else. The carosel does not turn at all. The discs do not index when you Turn it on. I have the service manual and did some tests. here are my results:
Turn on Normally >> Display shows D001 T01 and nothing works
Start holding Library Button down Goes to Initalize and sits there, disc does not index
FCT Mode
__________________________________________
Plus1 Play Motor trys to turn but can't
Plus1 Eject Motor trys to turn but can't
Plus 2 Play Does Nothing Except Display shows Open
Plus2 Eject Does nothing Except Display shows Close
Plus 3 Play Works Normally
Plus 3 Eject Works Normally
Text Display works as it should
Open Nothing
Eject Nothing
Disc Flip No errors, everything OK
Play and stop work,
Clamper Motor turns disc
Skip Forward and Back work
Inspection Mode
Play Does nothing display shows Inspection
Stop Goes to Inspection
Disc Flip does nothing
User File Does Nothing
Musci Type Shows CPPM key ID
It seems like the Carousel is "Stuck" It will play and the Clamper motor will rotate the disc in FCT Mode.
When I moved from one house to another, the movers packed it up and it was loaded with discs. I had to pull the cover off and get all the discs out which were all over the place. It is possible that at some point it tried to run with a couple Hundred discs out of place.
Personally I think that would be Bad But I ain't nor repair guy so what do i know. I can solder and use a DMM, use Jeweler Screw Drivers, but thats about it as skills are concerned.
Any help would be appreciated!! |
nv g500em 645 NATIONAL • S288 1 Fly Bird • 2530 Parallel Test Keithley • 2sa1105 WingShing • STANFORD RESEARCH SYSTEMS DS335 Operatio • UB [radial thru-hole] ACM-CD1XH Series U • plw sc.nt.ntr.ls apple • n55repairmanual Nikon • TL (2011) [screw-terminal] CDIN Series • m64ablk LG •
