switchbacker Guest
Posted: Sun Mar 08, 2009 4:35 am Post subject: Sony KV-35V36 T602 |
Thank You jts1957!
R607 was open on G board.
On A board I found bad solder joints on T501 (resoldered)
Q501 did not appear shorted but I replaced it.
I just want to inquire about T602 before powering up
the TV.
T601 looks like a Transformer but all 5 pins are short circuit?
If anyone could let me know if it should be replaced I will
be grateful.
Thanks Again.
Switchbacker |
switchbacker Guest
Posted: Sun Mar 08, 2009 4:37 am Post subject: T602 |
I meant to say T602 has short circuit across all pins.
Thanks
Switchbacker |
Posted: Sun Mar 08, 2009 7:22 pm Post subject: |
What about Q601 and Q602? |
switchbacker Guest
Posted: Mon Mar 09, 2009 1:25 am Post subject: T602 |
Yes I changed Q601 and Q602
But I don't know why T602 on A board would show continuity between all 5 pins?
Thanks
Switchbacker |
Posted: Mon Mar 09, 2009 6:21 am Post subject: |
T602 is a Line Filter on the "G" board. (The schematic only shows 4 pins).
If you have continuity on all pins...most likely causes:
Plug may be plugged into an isolation transformer and you're reading that; or degauss relay could have "welded" contacts and you're reading thermistor/degaussing coil; or one or more diodes in D602 Bridge rectifier are shorted. |
Posted: Mon Mar 09, 2009 2:22 pm Post subject: |
Did you test continuity out of circuit? |
switchbacker Guest
Posted: Tue Mar 10, 2009 4:24 am Post subject: KV-35V36 |
I must apologize to jts1957 and minnie.
It is T502 that has all pins continuous.
And it is on the A board right beside T501 .
I also checked it on another A board from a Sony KV-34SL40
and that is also continuous across all pins.
I believe it is a Transformer between
PIN Drive/out and the Deflection Yoke CN501.
Even if the deflection Yoke Cable is disconnected it shows all
pins continuous
I did not take it out of circuit.
The KV-36V36 parts manual calls it Transformer Ferrite(PMT)500uM
1-429-408-11.
Thanks
Switchbacker |
Posted: Tue Mar 10, 2009 4:43 am Post subject: |
See why it's important to try to proof read before submitting.
It IS a transformer.
Again, the schematic shows only four pins being used, Pin 6 & 8 are on pin output side through C514 with Pin 1 & 4 in the yoke return. Pin 4 & Pin 6 are tied together, hence the continuity reading. |
Posted: Thu Mar 12, 2009 3:02 am Post subject: |
Please do not do multiple threads. I will delet them. We are here to help each other and if you keep it in one thread it helps future 'seekers' find their answers. |
