mjl1297
Posted: Sun Mar 15, 2009 12:30 am Post subject: Yamaha K-500 cassette deck |
I have a Yamaha K-500 cassette deck that has served me faithfully since I was in my early twenties. It is still on active duty in my component system although it doesn't see nearly the use that it once did of course. Indeed I would venture to say my Technics turntable gets more "exercise" than it does.
Anyway it has always functioned flawlessly but the other day I popped one of the few cassettes I still have in it and the motor made a rather disconcerting grinding noise and shut off. There was no mechanical obstruction that I could see so I removed the tape and operated it with the cassette removed. In forward and reverse modes it will only run for a few seconds and then it shuts off. Pressing play it still makes makes the grinding noise and the heads do not engage the tape as far as I can tell.
Anyone have an idea what is going on here? I have found a service manual for it online but I'm hesitant to purchase it as I have concerns about the ready availability of replacement parts which I will doubtless need for it as I'm certain that one of the servomotors is involved here.
Thanks in advance! |
Posted: Sun Mar 15, 2009 11:39 am Post subject: |
| Belts? |
Posted: Sun Mar 15, 2009 11:17 pm Post subject: |
| Would belts cause behaviour like that? I was thinking that the spindles wouldn't even rotate in that case. |
mjl1297
Posted: Sun Mar 15, 2009 11:51 pm Post subject: |
| Sorry jts1957 but that is my response above. I thought the forum had looged me in when I posted. |
Posted: Mon Mar 16, 2009 1:38 am Post subject: |
Take a marker and put a dot or line on any guide, pulley, flywheel, idler, etc. that the belt rides on. Then try a mode.
The motor should have a pulley which turns a belt which then moves and turns the next thing in its "path," etc.
For example, if a unit has a motor, a belt and a flywheel ... if the motor pulley spins, but the flywheel does not, either the belt is bad or the flywheel is frozen and can't turn. |
Posted: Mon Mar 16, 2009 1:56 am Post subject: |
| Ok I'll get it out and open it up tomorrow and do just that. I'll post with an update later. |
mjl1297
Posted: Sun Apr 05, 2009 9:31 pm Post subject: |
| Finally got around to this. No belts that I can see but they must be there. This machine will run for a bit and then shut off regardless of whether there is a tape inserted or not. Need a service manual I think but no luck there. |
mjl1297
Posted: Sun Apr 05, 2009 9:40 pm Post subject: |
| Found a service manual to order--give that a try. |
mjl1297
Posted: Sun May 03, 2009 4:48 am Post subject: |
Definitely a belt issue as they had all deteriorated into so much goo--nearly impossible to remove. Bought the service manual and it tells me everything but how to replace the belts!  |
Posted: Sun May 03, 2009 5:00 am Post subject: |
Scrape away the majority of "goo" with a small pocket screwdriver. A Q-tip dipped in rubbing alcohol will remove remainder (allow to evaporate - don't allow on good belts).
Once you've completed that, you should have a fairly good idea of how the belts were routed, and probably, what must be disassembled to allow replacement. |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
