mikmar
Posted: Sun Apr 05, 2009 4:38 pm Post subject: Toshiba 42H83 problems |
I have a Toshiba 42H83 that had the hyper module problem spoke about in many forums. I replaced all 11 10uf capacitors and fired up the TV and all was good. I turned on the set the next day and after about ten minutes half of the TV had vertical colored lines in it. I am thinking it may be the convergence IC's that went bad. I also get an error when trying the auto converge. I can get into the service mode and line everything up but when I try to save the convergence points I get an error. But so close to the last repair it makes me suspicious. I was very careful about the repair and had no issues. I did not replace the 100uf capacitors in the hyper module and am wondering if I should have. Also if you think it is the convergence IC's which do I use? The originals ar Sanyo STK392-110. Should I use STK394-180 or STK394-250? Thanks in advance. _________________ mikmar |
Posted: Sun Apr 05, 2009 8:28 pm Post subject: |
| STK392-180'S or STK394-160's. |
mikmar
Posted: Sun May 03, 2009 12:26 am Post subject: |
Do these pics look like convergence IC issue?
[img]http://www2.snapfish.com/thumbnailshare/AlbumID=455546023/a=447721023_447721023/t_=447721023 _________________ mikmar |
Posted: Sun May 03, 2009 1:27 am Post subject: |
| Hyper. |
mikmar
Posted: Sun May 03, 2009 3:03 am Post subject: |
What specifically in the hyper module? I just replaced the 10uF caps. Maybe I should go for the 100uf caps next? Any ideas? _________________ mikmar |
Posted: Sun May 03, 2009 3:59 am Post subject: |
Recheck your work. Easy to break/lift a trace.
I feel the timing is just too close between the failures. |
mikmar
Posted: Sun May 03, 2009 4:19 am Post subject: |
I agree. That was my first thought. The funny thing is after the first repair the picture looked great for one day. Then I turned the set on the next day and got that. I will recheck the work. Thanks. _________________ mikmar |
Posted: Mon May 04, 2009 12:49 am Post subject: |
| Also replace all the 22uf/16v, 2.2uf/50v, 1uf/50v caps. |
mikmar
Posted: Fri May 08, 2009 3:16 am Post subject: |
I changed the 470uf, 100uf, and 220uf caps in the hyper module. It made no difference in the picture. I am ordereing the 1uf, 2.2uf and 22uf caps. K noticed that each convergence IC has six resistors. Three 1.8ohm and three 220ohm. The 1.8ohm measure the right value but the 220ohm measure .5 ohms. Is this an indication of bad convergence IC's? I measured the resistors I'm circuit. _________________ mikmar |
Posted: Fri May 08, 2009 3:32 am Post subject: |
| Were the convergence yokes unplugged? If not, unplug and test the resistors again. |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
