xh9wu1
Posted: Tue Jun 28, 2005 12:12 am Post subject: Toshiba 43H70: jumpy image, bad convergence |
I have been very happy with my 43H70 (rear projection) TV for more than 4 years. All of a sudden, when I turned it on on Saturday, the image was very jumpy to the degree of non-watchable. The convergence also seemed bad, which may be caused by the jumpiness. The TV would kind of turn itself off after 10 to 15 seconds (although it is not complete off since the power light kept blinking). I asked a local repair shop about this and it would cost $150 for them to come out and give me an estimate. I would like to know if this is a simple repair or I'm facing major problem, in which case repairing the TV is no longer attractive. Any help is appreciated!!! |
rufftv Guest
Posted: Sat May 13, 2006 1:55 pm Post subject: Toshiba 43H70 convergence + jumpy (jittery) |
The research I've been doing indicates that replacing the convergence chips may solve the problem. Two chips, STK392-110, $14 each at K&B.com. If you can solder 18 leads on a chip, that is. If not you, then perhaps your friend. |
Posted: Mon May 22, 2006 7:04 am Post subject: |
Update the stk's to 392-150. They last longer. |
cverneau Guest
Posted: Mon May 29, 2006 8:03 pm Post subject: |
I've just replaced both STK392-110 chips.
This fixed my problem of the jumpy image and the set turning off.
I stiil have a problem trying to get the red into convergence.
It seems as if it's tweaked off as the crosshairs are not true crosses, but have a slight arc to them.
Is this something that can be corrected by getting into the service menu??
Where can I get the service manual if this is the case?? |
bill9876 Guest
Posted: Sun Jun 04, 2006 11:17 pm Post subject: Toshiba 43H70 - Did the stk's 392-150 fix the problem ? |
Is it hard to replace Stk's 392-110 (or the 392-150), can somone tell me where it the television these are located ? |
DCR-TRV410_X SONY • service.zip R8 FOSTEX • FDS6679AZ - P-Channel PowerTrench MOSFET • [pencap radial] TH Series Teapo • UREI-1181 . Various • MAIN B Rolsen • SCHNEIDER • FM AM Stereo-clipper 3312 Nordmende • info Samsung • 4010 SGS •
