28pw6005 led flashes but cant change channels?
19bc80
PostPosted: Sat May 09, 2009 10:54 am    Post subject: 28pw6005 led flashes but cant change channels? Reply with quote
when i push a button on my remote the led on the tv i flashing (so the remote works) but nothing happens Sad tryed with a universal remote same problem led on tv flashing when pushing button but nothing happens Sad
hope someone can help have been searching the net but no luck Sad
greetings
19bc80
PostPosted: Sat May 09, 2009 1:21 pm    Post subject: Reply with quote
What about pushing the "power" button located on the set? Smile
19bc80
PostPosted: Sat May 09, 2009 1:24 pm    Post subject: Reply with quote
its the only way to turn it on but then it says locked because we put parental control on it but i cant change channels with the remote and buttons on tv is also blocked i need the remote to work so that we can remove the kode or can i reset the tv somewhere?
PostPosted: Sat May 09, 2009 1:31 pm    Post subject: Reply with quote
"Brand" also might help.
Owner's manual should specify if there's a master reset/unlock code for your set. Smile
19bc80
PostPosted: Sat May 09, 2009 3:00 pm    Post subject: Reply with quote
i have been looking i have got the service manual with every thing inside the tv but cant seem to find any reset and i have been looking inside to see if anything is broken i have tryed everything Sad i tryed that service code 062596 text-i but since i cant punch any numbers in it aint working im stuck here
PostPosted: Mon May 11, 2009 8:21 am    Post subject: Reply with quote
if the line output stage is running, ( quick check is see if the crt heaters are lit ) then there are 2 likely causes, first is ic 7064 the painter ic, the 2nd is that the crts emission has fallen to the point where the auto grey scale cannot balance the emission.
PostPosted: Mon May 11, 2009 10:50 am    Post subject: Reply with quote
I can't find full PHILIPS Owner's manual (in English), but downloading one in another language and then translating Idea
It does appear that the instructions for changing / setting / unlocking when code is forgotten are all there. Sounds like you MUST use the ORIGINAL remote. Smile
http://www.p4c.philips.com.cn/cgi-bin/dcbint/cpindex.pl?slg=ENG&cat=TV_CONVENTIONAL_CA&sct=WIDESCREEN_MEDIUM_25_28_SU&grp=TV_GR&session=20090511183312_68.251.40.139&ctn=28PW6005/01&mid=Link_UserManuals&hlt=Link_UserManuals
