trailmix86 Guest
Posted: Thu Jun 25, 2009 10:47 am Post subject: Convergence Problem? |
| I have a Hatachi 50" ultravision HD tv (sorry,no model #)that has begun to loose focus, (Blue and Red) outline of the picture screen. Upper right screen is seems ok. Have used manual went through the Magic focus with no change. What can be done or is it worth having tech to fix. I had it about 3 years, TV is about 7 years old. Any help appreciated. |
Posted: Thu Jun 25, 2009 12:14 pm Post subject: |
I presume you'd like exact location numbers, part numbers, etc.
Hard to google, look up prior repairs, etc. when Model Number = NONE.
Will be on the rear cover and is usually repeated somewhere inside the set. |
trailmix Guest
Posted: Fri Jun 26, 2009 12:23 am Post subject: Convergence problem? |
Thanks jts for your reply. Knew would need the pn, but forgot on way to work.(excuse i guess)
I have model# 53FDX20B, dtd june 2002 Problem as stated with the red,blue colors outline figures and letters. Faces are almost all RED.
TV was given to me, no past repairs known. Interested if I do put money
in to fix will it hold up or crater year so down road. I |
Posted: Fri Jun 26, 2009 12:35 am Post subject: |
| Replace the STK392-110's and check for any open/changed value bias resistors. |
trailmix Guest
Posted: Fri Jun 26, 2009 12:45 am Post subject: Convergence problem? |
| Thanks again for your help will pursue and go from there. |
trailmix Guest
Posted: Tue Jun 30, 2009 6:04 pm Post subject: Convergence Problem? |
| Thanks for the insight, problem fixed. Repaired by service tech. of problem quoted |
www.lipetsk.name
boom.bg : аукцион -
MondeTech
SEO -
Онлайн поща -
