marcoment Guest
Posted: Fri Jul 15, 2005 1:19 am Post subject: Mitsu CS 35401 old 35" TV problem |
I got a Mitsubishi 35" CS35401 television that will only stay on for about 30 seconds before going black. When the picture is visable, it is clear but ends up rolling vertically down the screen. The sound still stays on but the picture goes away. I opened it up and cleaned it out pretty nicely and did not see any visual damage of any sort... After cleaning all the dust out, it seemed like the picture stayed (not 100% stable though) for about 5 minutes rather than the 30 seconds it was on before. Any suggestions? Please lt me know =) |
Al_Dodge_Bundy
Posted: Fri Jul 15, 2005 11:05 am Post subject: |
Old TV's have often bad solder joints.
Try to gently tap on some components (special the flyback trafo) on the mainboard with an isolated screwdriver and watch if the picture comes back!
Good luck,
Mark |
VIEWVISION Guest
Posted: Fri Jul 15, 2005 1:25 pm Post subject: TRY LINE DRIVE |
HI I HOPE THIS ADVISE HELP YOU TO FIX YOUR PROBLEM MITSUBISHI R COMMON FOR DRY SOLDER ON LINE DRIVE TRANSFORMER DONOT TAP TO MUCH THUS IT WILL BLOW YOUR LINE OUTPUT TRNASISTOR JUZ REFLOW LINE STAGE HOPE THIS ADVISE HELP U TO FIX YOUR TV |
marcoment Guest
Posted: Fri Jul 15, 2005 3:29 pm Post subject: thank you |
thanks for the replys, should i be worried about any charge in any caps or anything while doing any of those? or posibly discharging the annode?
thanks again! |
Al_Dodge_Bundy
Posted: Sat Jul 16, 2005 7:37 am Post subject: |
If you have no experience in tv-repair, YES you should be very carefull when soldering on the inside.
Please leave the tv unplugged for an hour orso, so that the caps and any high voltage can discarge.
Good luck
Mark |
2sb689 NO • hfe aiwa hs-p08 g08 g500 service en AIWA • RR-630CD & 660CD Ver 2 Grundig • OB510 mri HP • p sd panasonic • Summary of Smalltalk Message Forms and I • 8753E User Agilent • 2302RevA DocSpec Keithley • 2sa1969 Sanyo • 2sd1170 Inchange Semiconductor •
