toshiba 32AV500U LCD inverter ?
Goto page 1, 2  Next
digitalscorpion
PostPosted: Wed Jul 01, 2009 6:26 pm    Post subject: toshiba 32AV500U LCD inverter ? Reply with quote
LCD model: 32AV500U
Has 2 inverter PCBs, Master and Slave. I have service manual. How can I go about finding which PCB is defective? Nothing visually bad. Does LCD need both functional to work? Any hints in right direction greatly appreciated.
PostPosted: Wed Jul 01, 2009 9:50 pm    Post subject: Reply with quote
What is the "Complaint?"
digitalscorpion
PostPosted: Wed Jul 01, 2009 11:39 pm    Post subject: Reply with quote
there is no backlight...
already diag'd to the source.... just wish I had more info from this point. No individual PCB schematic. No way to determine if both master and slave inverters are shot or just one. If so, does this LCD TV require both....?
PostPosted: Thu Jul 02, 2009 1:08 am    Post subject: Reply with quote
Or Bulbs?
Make comparative resistance readings of primaries / secondaries of transformers - one may be open.
PostPosted: Tue Jul 07, 2009 11:49 pm    Post subject: Reply with quote
32" should just be one.
digitalscorpion
PostPosted: Thu Jul 09, 2009 6:25 pm    Post subject: Reply with quote
There are two different revs/versions. One has single, one has dual (master/slave).
Still havent fixed, any more help out there? :/
Dan the TV man
PostPosted: Fri Jul 31, 2009 4:46 pm    Post subject: inverter boards Reply with quote
More bad news,it may not be inverter boards.It could also be t-con(lcd control board)over screen,Id replace capacitors in both inverter boards,and see what that does.you may have to replace all 3 boards.
calleriq
PostPosted: Mon Aug 24, 2009 3:51 pm    Post subject: Toshiba 32AV500U Reply with quote
my toshiba 32AV500U HDTV has green light but noting on the screen, what could posible wrong? Any suggestion, idea? please help, thanks
Dan the TV man
PostPosted: Wed Aug 26, 2009 8:34 pm    Post subject: Toshiba Reply with quote
Do you have sound ,and no picture.Probably inverter board(s).If you have no sound or picture,check for bulged capacitors in the power supply.If the power supply works you probably need a main board,also called a scaler board,or tuner board.The one the tuner and RCA jacks on it.
bradandjaya
PostPosted: Mon Oct 12, 2009 3:59 pm    Post subject: Another Toshiba 32AV500U w sound and no picture Reply with quote
A neighbor was throwing this 1.5 year old HDTV away... Now I know why.
Looking at the inverter boards, the master has had the 300uF capacitors and mondo transistor replaced at some time. The board is getting 24V on pins 1-5 of connector 1, and fuse appears to be in original, un-blown condition.
Other than indications of the above repairs, everything looks ok visually. I will check the transistor inputs to see if one is open, as I believe that is the issue.
Any ideas on how to get a supply of transistors (marked 331 81BHK)? Or is there a longer term fix to keeping this device working?
Brad
Goto page 1, 2  Next
Page 1 of 2
