bruiserman Guest
Posted: Thu Jul 21, 2005 9:51 pm Post subject: Transistor question if you know electronics please help! |
I need to replace a couple transistors and I have the numbers but don't know where to purchase them or what the numbers mean.
The numbers on the transistor are:
K30A
Y 5H <--- It looks just like that
If you have any ideas on what this all means that would be helpful as well as where I could buy two of these or if there are other transistros that would be compatible.
These are used in a Bass Guitar's active pickup board.
Thanks in advance
Brian |
Ray Guest
Posted: Fri Jul 22, 2005 3:11 am Post subject: |
More likely smal signal JFET transistor 2SK30A --- rather reliable device
How do you know they are bad? especially in a P/U ckt
Ray |
Posted: Sat Jul 23, 2005 2:13 am Post subject: |
I had a friend that thought the transistor went bad. He does know a bit about electronics but not sure exactly how much. The instrument was not working. So I tried replacing them. The transistors I put in seem to work ok but I will go find the ones your talking about. I have seen those. Yesterday I found the real reason for the bass guitar not working and it wasn't the transistors. Seems it had a controller that was grounding out. The inside of the guitar was lined with aluminum tape and that seemed to be causing the problem. I took the tape out and rewired a bit and now it works even with these other transistors I bought. Don't think they are exactly right though. Should have it fixed soon. Thanks for the info.
B |
AHA-C680-EXP LG • rn2101fs rn2102fs rn2103fs rn2104fs rn21 • Schlumberger-1637 SOLARTRON • SB TOP MYSTERY • VoluMax400 CBS • PACD000303CO panasonic • L3W30T Philips • CUC-4400 Grundig • 09 Model Upgrade Purchase Prices IBM • HP J2300C User Guide Agilent •
