Meowth Guest
Posted: Mon Jul 25, 2005 6:09 am Post subject: AC to DC to conserve energy, good idea or bad? |
Will I conserve more energy by using a 120v AC 60watt reading lamp, or
a lamp that has a built in transformer that has an input of 120v AC to
12v AC which uses a 12v 60watt bulb? |
absorbentgnome
Posted: Mon Jul 25, 2005 10:18 am Post subject: |
The 120V AC bulb will be more 'efficient' because it is directly connected to the power source. The 12V AC bulb requires the use of a transformer, which will waste some energy as heat.
The difference, however, is minimal. You'd be far better off using an energy saving fluorescent bulb/tube if you are worried about saving energy. |
Posted: Mon Jul 25, 2005 11:39 am Post subject: |
ur gay |
absorbentgnome
Posted: Mon Jul 25, 2005 12:07 pm Post subject: |
Retard. |
Posted: Tue Jul 26, 2005 3:56 am Post subject: |
absorbentgnome wrote: | The 120V AC bulb will be more 'efficient' because it is directly connected to the power source. The 12V AC bulb requires the use of a transformer, which will waste some energy as heat.
Thanks for the heads up |
Posted: Thu Jul 28, 2005 6:53 pm Post subject: AC to DC to conserve energy, good idea or bad? |
current=watts/volts.
The lower the voltage the higher the current.
120v better as a result. |
