Hitachi43fdx10b Guest
Posted: Wed Aug 19, 2009 12:21 am Post subject: Convergence problem |
I have a convergence problem before and I replaced both cirucit stk392-120. After I replaced I do not have video and audio . Any suggestions I am good soldering and I can read the multimeter but I am not good reading circuit. i think one capacitor or one circuit regulator died but I do not which one
Thank you |
Posted: Wed Aug 19, 2009 3:18 am Post subject: |
Just to make sure we're understanding each other...
Set had convergence symptoms (but was working);
You replaced STK's;
Set now doesn't work (No Video/No Audio)?
If I have it right, there must be a connection. You unknowingly may have done something that's causing the set not to work. A solder bridge or splash (can happen to the best of us), unplugged/loose connectors, bent one part lead so its touching another's lead, etc.
Of course, as you say, another part may have failed coincidentally. |
Posted: Wed Aug 19, 2009 5:16 am Post subject: convergence problem |
Thank you for the response
Like you said It was working before I was missing the green color (misalignment). I changed the ic twice the first time I changed with an equivalent circuit. and I have the problem and I replace with the original number. I checked today and I found a resistance with a broken ceramic, but it is reading resistance 2.7 kohms (rk05). |
plcnut
Joined: 18 Aug 2009 Posts: 6 Location: Missouri, U.S.A.
Posted: Wed Aug 19, 2009 5:28 am Post subject: |
check the little led lights on your power board. are all of them coming on, and is the red one flashing? when you power the set up which light turns off first? this will tell which circuit is causing the problem. Regards, Jason |
Posted: Fri Aug 21, 2009 12:05 am Post subject: convergence problem |
Hi I checked the board and I found a resistance open rk58 3.3 ohms I need to replaced, so after that i wil let you know. Thank you |
10 Wiring Diagram Samsung • tc5007 sch gif tokai • SM chassis LG MC-059 LG • Acer Ferrari 1100 Wistron Ferrari7 RevSA • OEM Delta DPS-182BP [SCH] . Various • 5991-4080EN IBIS AMI Modeling of Retimer • stp14nk60z ST • 2434Pw AOC • AD-F810 Aiwa • DOTEXT Nov76 xerox •
