Mike79079
Posted: Thu Aug 04, 2005 3:59 pm Post subject: Please anyone with repair help- Hitachi rearprojection Color |
Hitachi 60sx12b Ultravision-Color arc
My Hitachi ultravision set is displaying red, green color pushed down (arc0 in bow shape from top center of the tv. This will happen on and off. While this is going on magic focus will not work. But Now it is happening more frequently and it is moving toward almost from top to the center. Everthing shows in color. red & green. from top center to middle of the tv in bow shape.. Any assistence is really appriciated. |
mark
Posted: Thu Aug 18, 2005 10:25 pm Post subject: |
replace the convergence ics |
Posted: Fri Aug 19, 2005 12:07 am Post subject: |
mark wrote: | replace the convergence ics |
Yep, mine went out already they are cheap and pretty easy, located right at the rear on thebig heat sink, about 15-20 pins each. |
Posted: Wed Jan 25, 2006 5:39 am Post subject: |
I have replaced convergence Ics and I can see picture without any arc in the color. Wow.. but, I need my magic focus to work because picture in not clear.. I have read about the blue button, I could not find it. Model is Hitachi 60sx12b. Please any help really appriciated.. |
Captain_Cuevas Guest
Posted: Fri Sep 01, 2006 3:13 am Post subject: |
Can you provide the part numbers for the convergence ICs? I also have a Hitachi 60SX12B and red is always bowing in on the left side and occaisionally on the right side as well |
Posted: Sat Sep 02, 2006 12:48 am Post subject: |
In your set they are STK4274's, there are three of them. A wise person would replace all of them.
MD |
Posted: Mon Sep 04, 2006 7:36 am Post subject: |
Anonymous wrote: | I have replaced convergence Ics and I can see picture without any arc in the color. Wow.. but, I need my magic focus to work because picture in not clear.. I have read about the blue button, I could not find it. Model is Hitachi 60sx12b. Please any help really appriciated.. |
You need to toutch up the convergence in the service mode. Once that is done you have to reinitilize the sensor locations to be able to use magic focus. It's a pain in the butt! Theres a white button on the signal board at the front of the set. Puts you into convergence. IE never move green, andjust red and blue to green to make white, write the rom and store it. Three different convergence modes, end mode is the fine adjustment. Now if you don't get an overflow error, once you store the data, pip mode and pip mode write/stores data. 2/4/5/6 move cursor, ect. Email me and I'll send you the procedure. This is not for the faint of heart. They either go good, or you pull your hair out. Do not attempt unless you have all the information. I believe 0 and ant switch you between blue and red. You can play with it. As long as you don't store anything pip mode twice, shutting the set off will take you back to where you where. Pip mode pip channel is what reinitilizes the sensors. I'd see what someone would charge to do it. |
