jamhendriks Guest
Posted: Wed Oct 14, 2009 11:37 am Post subject: Denon CD-player DCD-920 open/close door |
When i operate the open/close button onmy Deon CD-player DCD-920 the CD-door opens, en when it is open it immediately closes aigain. There is no time to remove the CD.
If i operate manually the switches underneath the gearwheel on the CD-drive i have the same response. While the door motor is running opening the door and i manually operate the switch the motor immediately reverses his turning direction closing the CD-door.
What is the problem! |
jamhendriks Guest
Posted: Thu Oct 15, 2009 9:06 am Post subject: open/close |
I found the problem. The open switch on the CD drive was dirty ans did not make a connection when the CD-door was open |
Gosh_w Guest
Posted: Thu Oct 22, 2009 7:17 am Post subject: Denon DCD 920 Problem |
I've got another kind of problem with my old Denon DCD-920. When I put a CD and close the door, spinning motor doesn't work and on the tablo only zeros. The loading motor works. Please, give me advice. Thanks in advance! |
Posted: Thu Oct 22, 2009 10:43 pm Post subject: Re: Denon DCD 920 Problem |
Gosh_w wrote: | I've got another kind of problem with my old Denon DCD-920. When I put a CD and close the door, spinning motor doesn't work and on the tablo only zeros. The loading motor works. Please, give me advice. Thanks in advance! |
You have a slipping load belt that is not closing the tray all the way(though it looks like it is). Very common problem. You can try cleaning the belt if it has not turned in to mush or else get a replacement. |
Gosh_w Guest
Posted: Thu Oct 29, 2009 7:33 am Post subject: |
Thanks. I have replaced the belt. No result. Checked up switches - OK. Increased the current of laser - the unit came back to life, reads CD, CD-R. The sound is clear and musical. Pity, I think it's for a short time. Have ordered new LH KSS210A (original part) (15$ in this country - Ukraine).
I guess the last treatment could be the full cleaning of optical block. |
irgs14c40l International Rectifier • R3265A R3271A Spectrum Analyzer Vol III • SAA7126H 7127H 2 Various • stereo Tuner TS 2000 Saba • XL2 Midas • hfe pioneer sg-300 service add en Pionee • 070-5603-01 4404 Users Manual Dec84 Tekt • KNA-DV3100/DV3200 kenwood • GA7010C-TE MAKITA • e-166 Toshiba •
