PatNBrighton Guest
Posted: Mon Oct 26, 2009 10:52 pm Post subject: SONY 53" Projection TV Schematic needed |
Can you help direct me to a schematic or advise on likely component failure on the power supply board G-Board #A1316212A. The fuse is not blown. The TV does not turn on. Failed following a lightning strike nearby. Any ideas on locating a schematic or replacement board?
The Sony Projection TV model is a #KP53V25
Thanks |
Posted: Tue Oct 27, 2009 12:23 am Post subject: |
Regulator. _________________ You're over there, I'm over here. |
Boggs
Posted: Wed Oct 28, 2009 12:45 am Post subject: |
What regulator? Does this not sound like a convergence board problem? The TV would blink at its final stage of operation. Prior to this the TV would turn on but would require a warm up period of 10-15min where the screen would be white/grey color no true picture until the warm up expired. Then shortly after lines would appear on the screen then eventually fad out . |
Posted: Wed Oct 28, 2009 2:56 am Post subject: |
R607, Q601, Q602, resolder H.driver transformer pins. _________________ You're over there, I'm over here. |
TieDye Guest
Posted: Mon Nov 30, 2009 12:45 am Post subject: |
Long time to start with blinking LED usually indicates weak CRT. If no LED lights/blinks now, after lightning strike standby power supply +5V failure is probable. Q601/602 R607 problems will not stop LED from blinking at turn on request. probable CRT problems make this likely to be uneconomical repair. |
8100b Fluke • download1 Pioneer • Б. Боровски и др. - Микропроцесори - уст • daewoo cp-002 Daewoo • DVP3120 philips • 657U Philips • std90n03l std90n03l-1 ST • 4350 HP • adverts University • •
