Moriendi
Posted: Sun Nov 01, 2009 8:57 pm Post subject: Nintendo DS circuit board query |
Hi All.
I've got a kaput DS which is possibly fixable, but not sure. I know nothing about electronics apart from school level physics (and that was some time ago) - can use a soldering iron OK though!
It was dropped and can no longer switch on (as if power switch is broken).
I took it apart expecting to find a broken switch but instead a small component fell out - lucky I caught it because it's the size of a gnats fart.
It's this bit here...
http://www.n-mod.com/mods/DSL/layoutdsl/index.html
Look at the bottom picture (back of the mobo), go left of the white gunk, there's a component with "100" stamped on it, then another component, then the power switch with the black switch sticking out to the left.
See that component in the middle ? Black in the middle with 2 silver sides. It's that thing. What is it ? Is it a transistor ? The questions are - is it heat sensitive ? Can I solder it ? Is it polarity conscious ?
I can see clearly where it's come off the mobo, the legs are still on the mobo and there's enough to solder to.
Just wondering if it's fixable. Could buy a donor DS off Ebay but it would be good if I didn't have to.
Thanks all.
Moriendi. |
joester
Posted: Fri Dec 04, 2009 2:14 am Post subject: |
That is a surface-mount ferrite bead, and it's quite solderable. There is no polarity. Use as little flux as possible, and remember the 3 second rule...
Solder one side, 3 seconds max with heat applied, wait 3 seconds, solder the second side, heat applied 3 seconds max.
Joe |
DCR-TRV410_X SONY • service.zip R8 FOSTEX • FDS6679AZ - P-Channel PowerTrench MOSFET • [pencap radial] TH Series Teapo • UREI-1181 . Various • MAIN B Rolsen • SCHNEIDER • FM AM Stereo-clipper 3312 Nordmende • info Samsung • 4010 SGS •
