hentmanmd
Posted: Mon Nov 23, 2009 3:40 am Post subject: Reset Prestting channels Sony KV 19216R TV |
My old Sony KV1926R TV has several channels preset. The remote doesn't work at all.
How can I reset the channel presets so that all channels will come up in order when I push the channel up button on the front of the TV? The manual talks about using the remote to select channels, and then pushing the 'add; or 'erase' buttons on the front of the tv, but our remote is dead.
Howard |
Posted: Mon Nov 23, 2009 3:47 am Post subject: |
Program a "Universal" remote! _________________ You're over there, I'm over here. |
hentmanmd
Posted: Fri Dec 04, 2009 6:11 pm Post subject: preset channels |
I have a universal remote. When i select a channel, and press the 'add' button, i don't get the '+' sign to show that the channel was added, and when i go back to check, the channel was not added. What am i doing wrong? |
lervinfix Guest
Posted: Sat Dec 05, 2009 4:07 am Post subject: Re: Reset Prestting channels Sony KV 19216R TV |
hentmanmd wrote: | My old Sony KV1926R TV has several channels preset. The remote doesn't work at all.
Howard |
the only way to fix that is a remote..but is dead..how about i will teach you how to revived youre remote!!!if youre not throwing it away.. just open the cover and resolder all components that you see...focus to crystal component is a square one has 2 pin with labled 455 or 400..color yellow or blue..check it if the 2 pin has no cut...check also the sensor at the top..is like a LED bulb but it wasnt... |
panas8 TX28WG25C panasonic • Switch EP2050 046 Minolta • x ref c TOSHIBA • Sus'con [radial thru-hole] SI Series Su' • Epson EPL-5600 Service Manual epson • aoc d556t AOC • irfy340c International Rectifier • hfe pioneer dv-393-s service Pioneer • Philips 208U-07 MENDE (DE) • Quanta ZH8 SJM11-MS Quanta •
