wrazoru Guest
Posted: Fri Nov 27, 2009 4:15 am Post subject: Phone charging via USB & Wall plug? |
Hi....I've recently purchased an LG Incite phone which uses the USB port for charging. It charges either by USB wire when connected to a computer or by a power plug that plugs into the same USB connector on the phone.
I'm wondering how safe & feasible it is to charge the phone via the USB connector to other USB charging devices...eg. iPod charger...which works on the same principal that the device is being charged via a USB style outlet? Are ALL USB charging ports the same in terms of electricity specifications? Is it safe?
I read my manual for the phone, & it does say that charging via the computer will in some cases take 5-10 times longer than charging thru a USB power adaptor that plugs directly into a electrical wall socket. I'm assuming this is just because a greater current is being applied, correct?
THnaks in advance.. |
Posted: Fri Nov 27, 2009 6:35 pm Post subject: |
In general, the current draw is limited to no more than 500ma through a USB by design limitation regardless of the device. Depending on the device in question, as long as you are below 500ma, you should be OK. (hence the reason for wanting to use a separate adapter).
Another USB design criteria is the ability to shut down if/when 500ma is exceeded. Of course not sure of this validity for every cheap device in the market today? Either way with USB, as long as drawing around 5 volt at no more than 1/2 an amp there should be no problem.
Here is a good bit of info
http://www.girr.org/mac_stuff/usb_stuff.html |
Y22-2851-0 360 FE Handbook General Secti • Prology DVD-300BFM Prolodgy • 22sd2050 2 • vr540 910 Philips • SGH-X430 service manual Samsung • smh snapin UCC • pro-141fd krp-600m Pioneer • A9000 Grundig • Panel AUO G170EG01 V0 1 [DS] . Various • DENON D-MS3+audio DENON •
