nelson_paz_castillo55@hot Guest
Posted: Fri Dec 04, 2009 12:12 am Post subject: how to repair a lcd dell |
problem my lcd dell model m170eg01 once i turn it on will stay on but the picture itself goes on and off it seems to me like if is cycling somewhere either the power supply board or the pc board for proccessing the video signals, i need an advice or shlould i start testing parts at random starting with the power lsuppy board. or what should i do. thanks |
joester
Posted: Sat Dec 05, 2009 1:22 am Post subject: |
I'm going to assume (dangerous thing to do sometimes) that you are reasonably skilled at disassembling electronics since you mentioned testing parts at random.
First, use a high power flashlight to see if there is an image on the screen when the back light goes off. If there is no image, then the power supply is going bad. You can inspect it for the obvious things like bulging capacitors, bad solder, ect.
If there is still an image, I would suspect the inverter board. You might still get lucky and find a fault on the power supply in the 12V line, but I would lean towards the inverter board.
Joe |
KevinMartin
Posted: Tue Dec 08, 2009 10:12 am Post subject: |
If you want to testing your self then you have to knowledge of hardware and computer repairing. |
Color LaserJet 4600[1].part05 HP • Sigma+M430 +block+diagram++info+pack+12 • AC250I SB-SI 1273657385 LG • 5954-8262 series300techData Sep86 HP • C28-6594-4 PL1 F Programmers Guide Nov68 • SK66-TE-AT MAKITA • PD4213W-H, PD4213W-S, PD4213E-H,PD4213E- • 2sc4423 Sanyo • KV-21C5B Sony • Philips •
