banger
Posted: Mon Dec 14, 2009 12:07 pm Post subject: Philips 190/B6 Monitor OSD Fault. |
Hi all newbie to this board here. Been having some problems with my Philips 190/B6 and the OSD intermittently flashing on and off. I'm an Electronics Eng. but I'm very rusty so need some help in diagnosing the problem.
This is the second monitor with a similar fault, first being replaced under warranty, but second is now out of warranty.
Fault appears to be as if the "OK/OSD" button is being pressed bringing up the OSD on screen sometimes momentarily then going off.
I've already had the monitor apart and cleaned the control board, which cured for 3 months then the problem came back. I have just last night replaced the tactile switch for the OSD button, and again one day in this seems to have cured the problem for now.
But after removing the old switch - testing with an ohm meter shows the switch completely open circuit so I am doubting my current fix.
There appears to be three switches attached to one line, OSD/OK, UP and DOWN, each with a resistor of 47k, 10k and 1k0 respectively, pulling the line down when switch is pressed.
Can anyone point me in the right direction as where to look/test next ?
The service manual for the monitor including schematic can be found at
http://www.taservices.co.uk/download/190b6.pdf
Sorry for long post and thanks in advance. _________________ Tim  |
banger
Posted: Tue Dec 15, 2009 10:47 pm Post subject: |
Well it's started doing it again, short or replacing all the electolytic caps can anyone have a look at the service manual and suggest what to look at next? _________________ Tim  |
Joined: 24 Nov 2008 Posts: 1940 Location: Far, Far Away
Posted: Wed Dec 16, 2009 7:13 am Post subject: |
Turn unit "On" normally. Unplug the keyboard. If unit still acts up while keyboard is unplugged - keyboard is NOT cause.
Now if you're saying the unit will turn "Off" when you press the "OK/OSD" - then you should be looking at the "power" switch as the one possibly intermittant. _________________ You're over there, I'm over here. |
banger
Posted: Wed Dec 16, 2009 10:12 am Post subject: |
Thanks but the OSD switches itself on all by itself then off. Have checked the power switch and it seems ok, could it be a PSU fault? _________________ Tim  |
Posted: Wed Dec 16, 2009 10:28 am Post subject: |
| banger wrote: |
| Thanks but the OSD switches itself on all by itself then off. Have checked the power switch and it seems ok, could it be a PSU fault? |
It does this whether the keyboard is plugged in or not ... then keyboard can't be involved check logic/micro/system control, what ever you wish to label it. _________________ You're over there, I'm over here. |
Posted: Wed Feb 24, 2010 3:53 am Post subject: |
Some types philips lcd monitors have the same problems,exp 190s7.the swiths of controlboard under panel failed,this lead this problem.You can replace the switchs with good elements.Or,you can unsorder the switches for emergency.
sorry for my poor english
if you need pictures of the procedure,email me .serveral days ago,I had repaired one with same problem. |
banger
Posted: Wed Feb 24, 2010 4:46 pm Post subject: |
Have replaced the switches a while back and this seems to have cured the problem, thanks for the tip Guest.  _________________ Tim  |
Posted: Fri Nov 11, 2011 7:38 am Post subject: |
I have got the same problem, but don't know how to repair.
Can anyone help with illustration with photos?
Sa |
