gogo Guest
Posted: Mon May 31, 2004 2:26 pm Post subject: monitor trouble |
I have a problem with my monitor - the red color turned black and the green is pale. After some time of working the problem disappears by itself. The cable is OK. Does someone have any idea ? The monitor is TVM AS 5D |
zulexs
Posted: Tue Jun 01, 2004 5:40 pm Post subject: Re: monitor trouble |
gogo wrote: | I have a problem with my monitor - the red color turned black and the green is pale. After some time of working the problem disappears by itself. The cable is OK. Does someone have any idea ? The monitor is TVM AS 5D |
you can firs time chek the RGB then you tes the transistor and resistor |
sacho Guest
Posted: Wed Jun 02, 2004 5:50 am Post subject: |
Try to first resolder the picture tube socket . Review all the picture tube board for bad solders. If necessary, carefully remove the shilding
Good luck |
dolescle Guest
Posted: Wed Nov 24, 2004 8:11 am Post subject: picture tube |
this usually is a problem with the CRT on the picture tube..
try checking the CRT.. |
andycoranna Guest
Posted: Fri Jun 09, 2006 2:42 am Post subject: Re: monitor trouble |
zulexs wrote: | gogo wrote: | I have a problem with my monitor - the red color turned black and the green is pale. After some time of working the problem disappears by itself. The cable is OK. Does someone have any idea ? The monitor is TVM AS 5D |
you can firs time chek the RGB then you tes the transistor and resistor | |
andycoranna Guest
Posted: Fri Jun 09, 2006 2:44 am Post subject: intermittant rgb |
Resolder every joint on the crt base pcb! special attention to the crt socket. |
