POPEYE Guest
Posted: Sat Sep 10, 2005 10:32 pm Post subject: CHASIS A10 PHILIPS (hi minie) |
Hello
I want to change the chip painter position 7064 (micro) of a chassis philips A10e
I need information.
do I have to configure the chip? or is it to remove the old one and to put the new one?
please to directly also answer to my address
THANK YOU from Spain
[email protected]
¡¡¡¡ONLY I WANT KNOW IF I HAVE DO CONFIGURATION MICRO
SORRY MY ENGLISH |
Brian Hoskins
Posted: Sun Sep 11, 2005 8:49 am Post subject: |
When you replace the painter IC on the SSB panel you're going to need to put in all of the service adjustments specific to your television. If your set is working enough that you can get into the service mode I'd advise you to go through all of the setup menus (Geometry, Tuner, etc) and take down ALL of the setting values on a piece of paper. Then, once you've replaced the painter IC, put all of those setting back in.
If the fault on your television doesn't allow you to do this, then you need to find yourself a working set of the same model and take down the information from there instead.
Brian |
Brian Hoskins
Posted: Sun Sep 11, 2005 8:51 am Post subject: |
Oh just one more tip. When you replace the painter IC, the set does some kind of initialisation the first time you switch it back on. DO NOT INTERRUPT THIS PROCESS. The set will take a few seconds to display the picture, don't turn it off at the mains until this happens.
Brian |
Posted: Sun Sep 11, 2005 3:18 pm Post subject: |
Do what Brian said. Write down everything. It's a pain in the xxx. |
10 Wiring Diagram Samsung • tc5007 sch gif tokai • SM chassis LG MC-059 LG • Acer Ferrari 1100 Wistron Ferrari7 RevSA • OEM Delta DPS-182BP [SCH] . Various • 5991-4080EN IBIS AMI Modeling of Retimer • stp14nk60z ST • 2434Pw AOC • AD-F810 Aiwa • DOTEXT Nov76 xerox •
