djw Guest
Posted: Tue Sep 13, 2005 4:49 pm Post subject: Mitsubishi projection TV- picture squeezed |
I have a 4 year old projection Mitsubishi projection TV that has a problem with the picture looking like it is being squeezed in the middle. The problem is intermittent. Any ideas about what is causing it or how to fix it? |
Posted: Tue Sep 13, 2005 6:07 pm Post subject: |
Sounds like a pincushion problem. What’s the model #? |
DJW Guest
Posted: Wed Sep 14, 2005 10:17 pm Post subject: Mitsubishi projection TV- picture squeezed |
WS-55819 HD 1080 Medallion series |
Posted: Tue Sep 20, 2005 12:50 am Post subject: |
I don't know on that modle. |
wiley Guest
Posted: Wed Sep 21, 2005 7:35 pm Post subject: |
check for bad solder connections on the diodes and caps that are on the emitter of the HO transistor, also in the pincushion area. Look at the caps to see if they are swelled or distorted in any way. |
rickmoneck Guest
Posted: Sat May 20, 2006 2:28 am Post subject: |
look for a cold solder joint on the pin amp! |
dralexander Guest
Posted: Sat Jun 03, 2006 10:56 am Post subject: Projection TV will not power on |
I have a Mitsubishi VS-6051 Projection TV that was working fine until a couple of weeks ago. Now, when I press the on/off switch in the front lower left side of the TV it makes the sounds like it is powering on, but then does nothing , and the little green light which use to come on, never does.
Any suggestions? |
FFH-376 trouble LG • Canon BJC-8200 Service Manual CANON • 04vari NOKIA • 019ABLK LG • 2sa1815 Sanyo • Philco PH42LED A2 LED TV SM PHILCO • 19 Marantz • L20V36 ZENITH • Aqarius CTD00 Hotpoint • 2raars NOKIA •
