yacaman31 Guest
Posted: Sat Feb 20, 2010 3:20 am Post subject: Magnavox 37" LCD 37MF321d |
I found opened up the Tv and discovered that the power board is smoked. 2 capacitors were bad and on the back of the board were the caps sit are smoked too. Where is a good site to find the replacement board? Should I try to replace the bad capacitors and bad resistor?
Sutil_22 Guest
Posted: Sat Feb 20, 2010 1:01 pm Post subject: Check for power supply |
yes! replace all the bad components but first isolate the problem before you power on. Also check your bridge rectifier diode and check the power regulator. if all of the said components were okay. you can now proceed checking your P.supply. isolate your power supply do not attach the output line to the main board. then power on. check the power line output. if it is stable. turn off the switch then assemble the p.supply board to the main board. turn on but make visual observation. i hope this can help you..that is the basic rule when troubleshooting p.supply.. |
DHC-X200 & X250 v2 Daewoo • ta-s7av 394 panasonic • GTH400 JBL • 773 a Philips • bfn21 Siemens • 3400S-903 (B - Jan 2007)(QSG) Keithley • GF350 Teac • BM300 gebruikershandleiding DE`LONGHI • SAFAR 542 RF IF AF and Power Supply unit • sm chassis alpha3 panasonic •
