shnoob
Posted: Tue Sep 20, 2005 2:31 pm Post subject: Reducing Amperage |
Hi.
I want to reduce the amperage of a 12v 1amp 120v plug in power source to .28 amps to power a computer case fan in a different application.
Can I do this? If so, can I add more than one fan to the line without further loss of amperage?
Can the .28 amp fan run with a supplied amperage of 1amp without burning up?
Thanks in advance. |
fongs Guest
Posted: Wed Sep 28, 2005 7:02 am Post subject: |
I'm not entirely clear on what u want to do. Do u have a rated 12V, 1A power adaptor to be used with yr casing fan?
If the above is true, it shouldn't be any problems since yr fan will only consume up to 0.28A of what yr power adaptor could supply. There's no need to reduce "amperage" as u thought... |
fongs Guest
Posted: Wed Sep 28, 2005 7:08 am Post subject: |
Oh, if u want to add more fans to the same power source, u should connect them in parallel:
12v +
F1 F2 F3
Also, 3 fans is the max here (1A / 3 = 0.33A). Any more than that will result in reduced fan speed & overloading of yr power adaptor. |
PoxyPig Guest
Posted: Mon Nov 30, 2009 11:45 am Post subject: |
Sorry, you make no sense whatever!
A 120V computer case fan?? All the ones I've seen recently run from the 12V power supply.
As for amperage - there's no such word. Are you referring to current??
Current is measured in Amps, short for Ampères. |
