pete66
Joined: 13 Mar 2010 Posts: 2 Location: Adelaide, Australia
Posted: Sat Mar 13, 2010 8:24 am Post subject: Nintendo DS, can you identify this component |
Hi, forum newbie, hope this is the correct place to ask.
I have a Nintendo DS with a dislodged SM component that I cant resolder. Cant get the solder to wick onto the component pads. Circuit board pads are fine. I'm thinking about trying to source a replacement component, if only I knew what it was!
Its the component at L2 half way up the left hand edge of the rear of the board pictured at:
http://www.n-mod.com/mods/DSL/layoutdsl/index.html
Any help would be much appreciated.
And on a forum usage note, if there is a similar topic already, should I post to that or create a new one?
thanks
Pete |
Posted: Sat Mar 13, 2010 6:16 pm Post subject: |
In general, Lxx denotes a coil on a pc board and I am pretty sure that is what you have. Ofcourse it is next to impossible to determine it's true value without a diagram. However in this case the value is more likely not critical and you should be able to use a similar size component--have you tried using solder flux? Unless the ends (shiny part) have been torn off/damaged, you should be able to solder it back in place. |
pete66
Posted: Sun Mar 14, 2010 11:05 am Post subject: |
Thanks vtech,
yeah, I had thought that Lxx would denote an inductor of some sort though I thought the component with the 100 on it was the coil. I was not very clear sorry, its the small black component just above the one with 100 on it. Strangely, its looks to be labelled L2 but I guess thats referring to the component group??
And yes, I only have one one shiny end on the component so I dont think its reusable unfortunately. I think I need to read up on soldering surface mount components!
cheers
Pete |
Posted: Mon Mar 15, 2010 3:03 am Post subject: |
They are both coils. Difference is in the structure which will give a much higher value; the ones with 100 stamped on top appear to have a metallic core. |
OEM PWE4235 [SCH] . Various • ipp60r600cp rev2.0 Infineon • va730m-1 sm Viewsonic • • LG-OLED+TV+55B7-EA71B LG • GFG-813 GW-INSTEK • CE152 Philips • PIM1 500RevA DocSpec Keithley • TREC [radial] BA Series TREC • Tuners Selteka Selteka •
