cmdrdan Guest
Posted: Wed Oct 12, 2005 11:20 pm Post subject: Who has got this relay |
I am looking for a relay to replace one in a Sharp 27n-s100.
It is an OEG SDT-S-109LMR.
I can find specs and diagrams of this relay but I can't find anyone who sells them except for wholesale with huge minimum purchases. |
Ray Guest
Posted: Thu Oct 13, 2005 1:07 am Post subject: |
Instead of searching for the generic number stamped on the part, find out the sharp part number(need service man ) --then more likely you can purchase it from a sharp supplier---You can also do a search by model number & pull up parts list on some sites
Let see, do not have the service manual handy, but does it happene to be the relay>> (RY701 marked on the board)?
If it is, sharp part number is RRLYJ0081CEZZ & can be purchased thru tritronicsinc.com or any other sharp parts supplier
BTW, R u sure the relay is bad?
Ray |
Posted: Fri Oct 14, 2005 12:12 am Post subject: |
Thanks Ray I'll check to see if it's RY701 , any case you've pointed me in the right direction.
I suspect this relay on strong physical evidence. Previous owner somehow knocked out the power button, which turns on a lever to push the button at a 90 degree angle on the board. The relay was directly behind it, cover had fallen off, and the circuit is clearly open. Apparently the user pushed a pencil or something through, not knowing they needed to push down, and they knocked the relay cover off and then destroyed it.
I don't have a circuit tester but I am sure enough of this to gamble on getting a replacement.
cmdrdan |
10 Wiring Diagram Samsung • tc5007 sch gif tokai • SM chassis LG MC-059 LG • Acer Ferrari 1100 Wistron Ferrari7 RevSA • OEM Delta DPS-182BP [SCH] . Various • 5991-4080EN IBIS AMI Modeling of Retimer • stp14nk60z ST • 2434Pw AOC • AD-F810 Aiwa • DOTEXT Nov76 xerox •
