Magnavox 20MT1331/17
Goto page 1, 2  Next
kevflanaman
PostPosted: Fri Oct 21, 2005 4:22 pm    Post subject: Magnavox 20MT1331/17 Reply with quote
I have a Magnavox 20MT1331/17 and all of a sudden one day when i turned it on the picture moved to the bottom of the screen. There is a 3 inch black bar at the top of my screen. I'm more familiar with computers since i never repaired a tv before. But i refuse to go to a ripoff tv repair shop. Any help would be greatly appreciated. Thanks guys
kevflanaman
PostPosted: Sat Oct 22, 2005 6:05 am    Post subject: any help would be great Reply with quote
Thanks guys
fongs
PostPosted: Mon Oct 24, 2005 6:00 am    Post subject: Reply with quote
Sounds like vertical deflection problem.
I would focus on the frame (ie. vertical) IC and/ or capacitors around it. I dunno abt yr TV but alot of them use the vert IC with the "LA7xxx" number. U shouldn't miss it as it is usually mounted on the heatsink...
G o o d luck!! Smile
kevflanaman
PostPosted: Mon Oct 24, 2005 3:46 pm    Post subject: Thanx Reply with quote
thanx alot man for the help. that's all i needed to know. Ur the BEST!!!! take care Very Happy
fongs
PostPosted: Mon Oct 24, 2005 10:40 pm    Post subject: Reply with quote
U R welcomed! Laughing
I would try re-soldering the vert. IC 1st... I fixed a Panasonic 21" with similar problem just by doing that.
If that doesn't work, a replacement of the IC and/ or the caps around it is worth a try. Do a google search to look for the data sheet of the IC to identify its pin out. This will tell u which are the caps supporting this IC.
Let us know how it goes... Cool
kevflanaman
PostPosted: Fri Oct 28, 2005 2:31 pm    Post subject: quick one Reply with quote
Im kinda new to this, exactly where is the vert ic. located? thanx
PostPosted: Fri Oct 28, 2005 2:32 pm    Post subject: Re: quick one Reply with quote
I did a search and couldn't find the data sheet Sad
kevflanaman
PostPosted: Fri Oct 28, 2005 4:50 pm    Post subject: took out main board Reply with quote
i took out the main board and I can send you pictures if that help. I apreaciate u halping me man.
thanks, kev
tjgmore
PostPosted: Thu Sep 25, 2008 7:23 pm    Post subject: vertical foldover problem Reply with quote
I'm an old tech and my niece has the same model and problem. what i found without a schematic was a shorted power diode(ref#6463) just left of the flyback(high voltage) transformer. after replacing diode with fast switching cross reference, I still have same problem but new diode is still good. I then found resistor(ref#3543) measured 82kohms but color code is brown,red,black which means it is 12ohm. That is either a misprint or resistor is bad. after soldering board and checking components, i need a schematic to diagnose further. If somebody has resistor(3543) value let me know or I'll have to spend $20-$30 for manual.
Hect7369
PostPosted: Fri Mar 06, 2009 5:34 am    Post subject: Re: vertical foldover problem Reply with quote
Resistor is good R5343(82k).
Check cap 2465,this fails often.check all surround components.
Goto page 1, 2  Next
Page 1 of 2
