jmja107
Posted: Fri Aug 13, 2010 11:53 pm Post subject: Toshiba 32A33 |
Hi guys I hope you can help me out, I went to turn my tv on the other day it clicked but no picture or sound, it appears the power light is blinking 3 times like some kind of code, any one have any ideas.
Thankx |
Posted: Sat Aug 14, 2010 2:02 am Post subject: |
Do you have the necessary troubleshooting skills, test equipment, ability to read a schematic, know how to test components and soldering/desoldering abilities? _________________ You're over there, I'm over here. |
jmja107
Posted: Sat Aug 14, 2010 9:01 am Post subject: |
I have basic skills, can't say i'm experianced in this, I have a multimeter, and I can solder,and read a schematic, and can trace circuts |
Posted: Sat Aug 14, 2010 12:18 pm Post subject: |
What DC voltage do you read "across" C810? (162)
What DC voltage do you read "across" C889? (19)
What DC voltage do you read "across" C884? (126) Remember this ground point, should be the same as tuner cover and is the ground that is used for all of the set except for Audio and primary of power supply.
What DC voltage do you read at F470 both sides (125) _________________ You're over there, I'm over here. |
jmja107
Posted: Sat Aug 14, 2010 2:48 pm Post subject: |
If I had a schematic for this model I could tell you but I havn't been able to find one for this model |
Posted: Sat Aug 14, 2010 5:25 pm Post subject: |
jmja107 wrote: | I have basic skills, can't say i'm experianced in this, I have a multimeter, and I can solder,and read a schematic, and can trace circuts |
This is how this works: I have the experience. You have a DVM. I specify what component (location number should be silk-screened on PCB) to measure/test. I even give expected reading. You shouldn't necessarily need a schematic (service manual easy to find ... with schematics, that's a little harder).
So let's see if you have raw B-Plus and/or switched mode power supply outputs. _________________ You're over there, I'm over here. |
