deomehta
Joined: 16 Nov 2010 Posts: 2 Location: Jamshedpur, India
Posted: Tue Nov 16, 2010 12:30 pm Post subject: Samsung scx-4300 problem after tonner refilling |
Hi all,
I have problem with samsung scx-4300 printer after refilling the tonner printer does not recognized tonner catradge..
please suggest the needfull
Thanks in advance..
Deo Kumar Mehta _________________ Deo Kumar Mehta |
deomehta
Posted: Wed Nov 17, 2010 9:37 am Post subject: |
How to reset samsung clx-4300 printer
Thanks & Regards
Posted: Wed Nov 17, 2010 11:23 pm Post subject: |
I think he wants to know "how to reset chip." _________________ You're over there, I'm over here. |
whintampz
Posted: Mon Feb 28, 2011 5:08 am Post subject: Re: Samsung scx-4300 problem after tonner refilling |
try this solution:...chip resetter samsung scx 4300 scx 4300 toner exhausted firmware scx 4300 scx 4300 tech mode
It must be "1.13fix" not "1.13"! Let's start again. To solve problem you need to download PATCHED by scx4300.exe 1.13 firmware where additional reset procedure was implemented in.
To patch firmware you need to unpack archive in any folder then open commad line interface go to this folder then type "fix4300.exe SCX4300_V1.13_Fact_romdl.hd". If no error occurs you will find file "FIX_SCX4300_V1.13_Fact_romdl.hd". It's a patched firmware. The next step is to download this file to printer.
Enter TECH mode, activate download by "Menu > Data Setup > Flash Upgrade > Local [OK]" then type in command line "usbprns2.exe FIX_SCX4300_V1.13_Fact_romdl.hd" to start download. During download printer displays:
Data receiving > Flash erasing > Flash Programming > Checksumming > Download Ok then printer will restart. It's all.
To reset all counters and unblock printer enter Tech mode go Data Setup > Clear counters. In this menu you will find "Clear All CNT" instead of "Total Page CNT". Choose "Clear All CNT" then press [OK]. Printer will display "warming up" and LED will yellow for seconds then change to green.
After reset all counters in report will be zero and toner 100%. You may repeat this procedure as soon as you need. |
