SiliHead Guest
Posted: Mon Jan 03, 2011 5:46 am Post subject: panasonic TV TX-28F250A |
Hi
Need some help on fault finding.
This TV started going off focus over time.
It now has bright horizontal lines when it is turned on.
After about 30 seconds it switches the screen off & seems to go to standby mode.
There's a red blinking LED at the power switch.
This chassis may be same as the TX-32F250A.
1. What voltages should I look for? and at which points?
2. What components should I check for short or open circuits?
Cheers |
Posted: Sun Jan 09, 2011 5:35 pm Post subject: |
It might be the GP2 chassis. Try to find out which it has. If it is the GP2, check these:
- IC880 temperature sensitive (with small black heatsink to the right of the tuner). 9V at CRT socket L2 pin 1 drops to approximately 7V, then appliance switches off.
- IC371 defective. Check resistors associated with the circuit.
- D558 is S/C and R57 is O/C. |
V9079-90001 V9079B TD-SCDMA User 2527s a • 058ats LG • [radial] MIN-13 Series Joemaster • aj-15 HEATHKIT • s a4 t panasonic • Compaq Armada 100S and COMPAQ • cd74hc166 Harris Semiconductor • [bi-polar axial] RMN Series Richey • bsc030n03msg rev1.16 Infineon • RCD 300 PASSAT B6 grundig •
