Posted: Fri Feb 18, 2011 1:24 pm Post subject: toshiba 43vj33q rear projection tv |
this set appears to be stuck in standby . however i can switch the set on by bridging pin 3 + 4 on the microprocessor then the power supply will provide all correct voltages according to the service manual but the screen is blank and no sound . i have replaced the three convergence ics SLA5041m but has made no difference . has anyone any ideas on what to check next .
regards
peter |
sweetguy68
Posted: Wed Feb 23, 2011 7:45 pm Post subject: about your t.v |
well first of all if you can't turn the set on normally, and you jump the prcessor, then i would think you need to replace the processor, or on one occasion, i found a bad cap right by the processor, either one will cause your problem,. carl _________________ i am a retired person, been in the electronics business for 40 years, am now in to the newer t.vs as well ,lcds and plasma |
KONKA • [radial thru-hole] CD269 Series Chirx • Philips L3F16T Philips • CM 10 cherokee • VP930-1 Series SB 009 Viewsonic • mitsubishi ct-25m5bt MITSUBISHI • hfe onkyo tx-sr605 sa605 sa8560 ONKYO • 22sa1256 2 • Panel CHIMEI INNOLUX N156BGE-L11 4 [DS] • TD-220 T Zanussi •
