stapa11 Guest
Posted: Sun Dec 04, 2005 3:09 am Post subject: Thomson icc17 33ms21e dead with blink 2 then 6 |
Hi there.
I have no service manual where I could check what means bilnking 2 then 6 times on my tv set.
Could someone help what happened?
Regards,
-stapa |
stapa11 Guest
Posted: Sun Dec 04, 2005 4:22 am Post subject: ICC17 Thomson blink codes |
Thomson TV Model: (ICC17 Chassis)
Standby led fault codes and meanings list / standby led flashes then pauses
Code meanings are as follows:
10 = child lock mode,
11 = timer mode,
14 = there is no response from Iv01,
15 = there is no response from IS40,
20 = bus access prohibited by software,
21 = bus data line held low,
23 = bus clock line held low,
25 = switched 5v supply missing,
26 = crt is not warming in the allotted time,
27 = deflection failure more than three times,
28 = IF01 guard voltage (pin exceeded,
34 = no response from the nvm chip IR03,
36 = incorrect address passed to bus handler,
37 = unexpected level on NMI line (power fail),
41 = bus data line not recoverable |
