wtomich Guest
Posted: Mon Dec 05, 2005 8:09 pm Post subject: RCA F25442 picture goes to snow |
RCA F25442, when watching it the picture will go to snow, no sound. For the most part the set works fine, it's just after some hours of watching it, it will just go to snow. When it does, some other channels may work. Sometimes, if you turn it off then on it will work. Tuner??? Thanks for your help. If it is a tuner, where cab I get one? What do you think it will cost? |
wtomich Guest
Posted: Tue Dec 06, 2005 7:11 pm Post subject: |
Can anyone help? Please. |
Posted: Sat Dec 10, 2005 9:55 am Post subject: |
Take it to an authorized Thomson Service Center and they will know exactly how to correct your problem. It's a very common problem with the Thomson sets, but requires a bit of skill to repair it right. If you let it go, the eeprom might possibly become corrupted and then the cost of repair will be extreme. |
wtomich Guest
Posted: Wed Dec 14, 2005 7:37 pm Post subject: |
Thanks for the response. Can someone explain to me what is wrong and can I fix it myself. Or what to expect a repair shop to charge. |
crx-si
Posted: Wed Jan 04, 2006 5:31 am Post subject: |
The tuner has cold solder joints. |
guest Guest
Posted: Tue Jan 10, 2006 10:10 am Post subject: |
Repairing solder connections inside a modern tuner, on board, or discrete, is very fine work.
Tuners are made as small as possible, in order to cut down on Radio Frequency Interference. The printed side (solder side) of tuner boards are covered with tiny surface mounted chips. Melting the solder can dislodge these, and some are so small, you might not even notice.
Unless you have quite a bit of experience soldering very tiny circuts, you may not want to attempt this.
What you could try, is the 3 points that hold the cover on the printed side of the circuit board. Heat them up, enough to melt the solder, and a tiny bit more. Do not heat them too much, and add only a small amount of solder.
This may repair the connection of the pins below the cover, to the printed circuit.
An experienced tech knows all of the affected connections, and how to properly resolder them. They often add jumpers to bypass future bad connections, all in less than an hour. |
SA-HT500E PANASONIC • 10th Generation PlasmaTV Panel Replaceme • Panel CHIMEI INNOLUX V315HH6-LS1 2 [DS] • V110CZ Toshiba • . lfm2. oscillator. circuit diagram Farn • 2sc3456 Inchange Semiconductor • 599742513HU AEG • lg cm9960 LG • hmc40tpem s6 panasonic • CF75, CF76 siemens •
