Daysleeper
Posted: Mon Dec 19, 2005 2:36 am Post subject: Philips 28PW6305 Powering off when SCART used |
I recently inherited a Philips 28” Widescreen (28PW6305) TV with a strange fault.
Basically it works perfectly until you plug a source into either SCART or the SVHS port, then roughly after 10 minutes it turns its self onto standby with the Red LED flashing (its not a precise flash, it goes dim then bright). Powering cycling the TV resets the fault and it will again be fine for around 10 minutes.
I have tried different sources; DVD, Cable, PC.. etc none of which make a difference. It still goes to standby.
Any help or suggestions would be greatly appreciated.
Thanks in advance.
Dave |
Posted: Sat Dec 24, 2005 12:52 am Post subject: |
ANY STRANGE FAULT ON A PHILIPS A10E CHASSIS TV IS USUALLY CURED BY REPLACING THE PAINTER IC, IC7064 ON THE SMALL SIGNAL PANEL, MAKE SURE YOU FIT THE CORRECT VERSION OF UPDATED SOFTWARE. |
2n5611 Semelab • mje13005 Inchange Semiconductor • hfe perreaux industries ep schematics PE • Pioneer • 2sd1778 Inchange Semiconductor • f200cd LG • 715G6338+PSU Philips • satellite 2400 2405 TOSHIBA • an 1200-5 HP • Panasonic TX-49FXW584 Chassis LA76 [X] p •
