newone
Posted: Fri Dec 23, 2005 9:42 pm Post subject: how to know the zenor diode how much watt and how much volta |
how to know the zenor diode how much watt and how much voltage
its red clor whith black |
Posted: Thu Jan 05, 2006 7:48 am Post subject: |
there is some numbers on zener.these number are about volts.tell me about to help you |
Posted: Sat Jan 07, 2006 3:00 pm Post subject: Zener Diode Power |
First, you try to find the part number from the manuyfacturer, in data books, on the 'net, or wherever you can find it. Do a search for the individuals and services who collect data sheets and offer the information to the public.
I'm sure you know that the power dissipated in a zener is the zener voltage multiplied by the reverse current through the zener. This product should be comfortably below the power rating of the zener under all possible operating conditions of the circuit.
If you can't find specs on the zener you are applying, test it as it will be mounted in your circuit and be sure it doesn't get noticeably hot under worst-case conditions, using either a very small temperature sensor like a bead thermistor or thermocouple or by feeling it. Crude, but better than nothing. If it is too hot to touch, the body is above about 140 degrees F and the junction inside the package is much hotter and under stress. (Obviously, you have to be very careful about touching an energized circuit if high voltages are present.) If you can comfortably touch the zener under worst-case operating conditions, it will probably be ok.
Another approach is to look up power ratings on known zeners in the identical package as your zener and apply a safety factor for the fact that you are guessing about comparability. Power dissipation is largely determined by the packaging and heat-sinking of the Zener.
Have fun.
awright |
MX800 Samsung • DVA-206LX Инструкция Funai • servo schematic diagram MYSTERY • • fw-46 fw-56 246 Philips • irl1004 International Rectifier • 2sb885 Inchange Semiconductor • dta143tca HT Semiconductor • system block diagram LG • ET News Letter 1955 IBM •
