Posted: Mon Dec 19, 2011 8:27 pm Post subject: Sony ZS-S2ip boombox no sound |
Hello
I have a sony zs-s2ip boombox that has no sound output at all. I tried all the functions ipod, radio and cd and none of these will output sound. I plugged in headphones and I get no sound either just a faint buzz. It appears this problem is common as I saw someone on amazon complain of the same problem with this equipment. What tools can I use to diagnose this? How can I diagnose this problem? Your help is appreciated. Thanks |
Posted: Tue Dec 27, 2011 10:26 pm Post subject: |
With such an off-beat user name of "Guest," NO means to get to a user profile, No email address in body of post, I'd suspect the probabili
ty of you receiving any response is nil (unless it's not). _________________ You're over there, I'm over here. |
I_Daniel Guest
Posted: Wed Dec 28, 2011 7:03 am Post subject: Boombox |
If you have played it at continuous full volume you can expect a blown final amplifier or speaker.
You need a VOM (volt meter) and an audio signal tracer.
1. check voltage. before and after the on/off switch. If non check the
power supply or batteries.
2. start at the volume control and check for audio with the signal tracer.
3. if no signal trace the wiring to the pre-amplifier and check for audio on
the output if non check on the input.
4. If there is sound at the volume control then check for sound at the power amp input. If okay check the output from the power amp. if OK then your speaker wires are either loose or the speaker is bye-bye. You can disconnect one speaker wire and check with the Ohm meter. You should get a very low Ohm reading anything from 1.5 Ohm to 10 Ohm. If no reading then the speaker is definitely broken
You must also check the voltage at each stage.
If there is an external battery connector then this sometimes remains open once you disconnect the external supply, so check this as well. |
I_Daniel Guest
Posted: Wed Dec 28, 2011 7:12 am Post subject: Boombox |
Another point. If you have a small radio/amplifier with an Aux input you can use it as a signal tracer. Make up a cable - A crocodile clip for earth and a probe, such as that of the volt meter, for the other wire. |
I_Daniel Guest
Posted: Thu Dec 29, 2011 6:16 pm Post subject: Sony BoomBox |
Sorry I did not read the original post fully.
Since there is a hiss on the speaker the final amp and the speakers are okay.
On another forum I gave the same advice but it turned out to be the volume control was open o.o.o and needed to be replaced.
But also check the switches to change from CD/cassette/Radio etc. |
2sd2251 Inchange Semiconductor • RXA3010 SCHE 2 DIGI 2 Yamaha • 5989-7177EN Keysight and Academia Partne • pbss4021pz Philips • E3701-003010-5 Erisson • 20TC646 NOBLEX • 42PX5D.part2 LG • E870 SVC Manual Samsung • 22pfl5557-v7 24pfl5557 32pfl5537 22pfl59 • Philips EL6435 Philips •
