Posted: Thu Dec 29, 2005 9:48 pm Post subject: matsui tv combi vhs video, model TVR 185T problem with av ch |
bought a dvd player, but av channel is very wavy when the dvd is plugged in, been thru the channel tuning process but it seemsd to skip the av section when i try to fine tune it, any help would be appreciated, regards |
sparky
Posted: Fri Dec 30, 2005 5:36 am Post subject: matsui tv combi vhs video, model TVR 185T problem with av ch |
A DVD player would connect directly to the scart socket on the back of the television and the AV channel selected and so does not require tunning but you may experience a problem if the DVD player has Macrovision installed (this prevents copying DVD's to tape by producing an unstable picture). _________________ If in doubt pull the plug out. |
Posted: Fri Dec 30, 2005 8:33 pm Post subject: |
thanks for the prompt reply, but it appears that the av channel isnt tuned in properly as the picture is wavy, its the same if i plug freeview in to this channel too, its just that i cant seem to adjust any picture when its in av mode, dfo i need to get a repair done or can it be adjusted manually |
sparky
Posted: Sat Dec 31, 2005 3:04 am Post subject: matsui tv combi vhs video, model TVR 185T problem with av ch |
Yeh it should work with freeview using the A.V button on the remote.
Enter the menu in the television and try both composite video and also RGB modes with a straight standard 21pin scart lead (not gold plated or using shared scart adaptor) and if no luck try chaging these same settings in the freeview but if still no luck try another scart lead. _________________ If in doubt pull the plug out. |
mpsw13 mpsw14 Motorola • 062aev LG • CUC-1828 Grundig • ntmsd6n303r2-d ON Semiconductor • x amp CARVIN • ES140-TE-AT MAKITA • 2sb852k Rohm • ENA-TDR 100Base-Tx Ethernet Cable MOI re • HP 181A 252C 181AR Operation Agilent • dhd550g dwu550g dwx600g dhd600g dwu600g •
