cr34tive
Posted: Sat Dec 31, 2005 8:10 pm Post subject: Philips 32PW8717C it just doesn't start up |
I appear to be having some problems with my Philips TV I hope there's someone that can help.
Here's my problem: I try to turn it on, so I press the on/off switch, there's the regular amount of clicks that you would expect to hear when a TV is about to start. However, the red standby LED goes from it's usual dim red illuminated state and just flashes, nothing else happens.
Any ideas would be gratefully received.
Many thanks,
Mike |
Posted: Sun Jan 01, 2006 12:26 am Post subject: |
This is EM2E chassis
1.
Measure immediately after switching on, the voltage on cathode of the diode 6499. If you measure there for a short time 8,2V, then please restart the set and measure at C2430 if the Voltage immediately after the start up is approx. -40V. If the Voltage have a lower value then replace D6616, C2610 and R3617.
The parts could be faulty. Therefore it is better to replace the parts even when the measuring result is O.K.
2. It happens very offen that the blue capacitor (C2420) near the linetransistoris burned. |
FlatTV
Joined: 01 Jan 2006 Posts: 1 Location: Brugge (Belgium)
Posted: Sun Jan 01, 2006 11:39 pm Post subject: |
Check resitor R3652 (22Ohm), if open replace also Tr7641 & Tr7652 (BC847b) and solder the heatsink near linetransistor.
Check also R3483 (E/W circuit) |
ipp90r340c3 1[1].0 Infineon • Panel CHIMEI INNOLUX N121I6-L02 0 [DS] . • 3310 nokia • SLPG490 Technics • 626A HP • TPM142ELA SB-EX-SI 1423472749 Philips • 29TJ70 01 Erisson • 8310-6510 Cable Nokia • GDM-400PS Sony • SCT55A Samsung •
