slotman6
Posted: Wed Jan 25, 2012 3:21 am Post subject: Westinghouse LD-3235 |
I have a Westinghouse LD-3235 that turns on but the back light does not turn on . If you shine a light on the screen you can see a picture. Anyone know what to look for it is a led TV.
Thanks |
Posted: Sun Feb 12, 2012 4:07 am Post subject: |
It would indicate a bad panel. |
Posted: Mon Jan 14, 2013 1:02 pm Post subject: Re: Westinghouse LD-3235 |
slotman6 wrote: | I have a Westinghouse LD-3235 that turns on but the back light does not turn on . If you shine a light on the screen you can see a picture. Anyone know what to look for it is a led TV.
Thanks |
I have this same problem but my screen will flash the "W" westinghouse logo fully illuminated for a fraction of a second when the set is first powered on. Afterthat, it will not illuminate at all again. Shining a flashlight shows good picture image on the screen, just no backlight. Any thoughts? |
Posted: Wed Jan 16, 2013 1:58 pm Post subject: Re: Westinghouse LD-3235 |
Anonymous wrote: |
For those interested, I got this figured out. There is an LED strip that runs across the inside bottom edge of the LED display panel. There is a plastic ribbon cable that is connected to each side of the LED strip that provides power to the LEDs that are the display backlight. One of the sockets where a ribbon cable attaches was not properly soldered to the LED strip, causing open or short circuit issues depending on gravity and position of the socket. It was totally free floating. I guess the processor would light the LEDs on start up then realize there's a problem and shut them down to prevent damage. I disassembled the LED display, resoldered the socket to the strip, and all is good. |
mpsa18 Fairchild Semiconductor • cph5508 Sanyo • Troubleshooting Samsung • 6641 AAC • nokia 7161 WEST GERMANY • ssg4520h Secos • mp4021 en wm 20061027 Toshiba • AV-R1603 Denon • buk9621-30 1 Philips • chm0603011ce 115 panasonic •
