canuck Guest
Posted: Tue Mar 27, 2012 2:07 am Post subject: Canon 9000F Scanner |
| I am looking for service information or schematics for the 9000F scanner or the AC adapter used in this scanner (QK1-6242). I would like to find out what the voltage outputs of the 3 pin output connector should be. Any info would be appreciated. |
Pentode
Joined: 30 Oct 2007 Posts: 83 Location: Nr. Manchester (UK)
Posted: Thu Apr 19, 2012 11:23 pm Post subject: |
I have the 8800F and mines a flat three pin type affair, above the socket it's marked 32V.
I would imagine its a switch-mode type power supply, also keep in mind mine uses LED and not the CCFL back-light tubes. I would check above the socket just in case it's marked like mine.
If there is no output probably the wire has broken just as it goes into the molded part of the plug, also the switch-mode supply could be faulty.
That's the best I can do for now.
Dave |
Posted: Thu May 03, 2012 11:01 am Post subject: Use its guide book |
| The best way is to use its guide book if not then search on google i hope you will fine something good according to your requirements. |
Åëåêòðîíèêà Ñîôèÿ -
Prikachi -
Pulsator
Íîâèíè -
áåçïëàòåí DNS -
Whois ðàçóçíàâàíå -
Poblizo.com : ïúòåøåñòâèÿ
CABLE-714 • TC-M • TC-SSM • VARTA-57662/401 • ENER-AP650MC • ENER-XP4001A • ENER-CR2016 • ENER-CR2025 • ENER-A27 • ENER-A23 • DVB-T HDMI10 • ENER-LR03 • BOX-VARO • TC-SS/3 • DVB-T HDMI20 • ANT-DVBT-IN •
