jfk84 Guest
Posted: Tue Jan 10, 2006 10:39 pm Post subject: PHILIPS TV MODEL 28PT4523/05 |
Philips tv model 28pt4523/05, chassis MD1.2E ?
Line output transistor short circuit.
Replaced and worked for 4 hours and went s/c again.
Any idea what is causing this ???
No schematics need a helping hand ...
Thanks in advance .
jfk : |
Posted: Wed Jan 11, 2006 12:36 am Post subject: Re: PHILIPS TV MODEL 28PT4523/05 |
jfk84 wrote: | Philips tv model 28pt4523/05, chassis MD1.2E ?
Thanks in advance .
jfk : |
Hello,
First off all it is important to replace the Output transistor by the same type.
Second : You will have to check on the solder joints of the connector of the deflection coil (I mean the big coil around the tube )
It is also possible that the blue disc capicitor 1.5 nf 2000 Volts ( very close to the line output transistor ) has a crack and sometimes goes short circuit.
I hope you can repair your tv now.
Greetings
Jeroen Hartman
TV/ Video/ Audio engineer
The Netherlands |
stevie
Posted: Sat Jan 14, 2006 12:36 am Post subject: |
It,s always a good idea to resolder the line driver transformer pins after output transistor replacement, I have been caught out on this one before. |
KX-TD290 PANASONIC • bd677a Inchange Semiconductor • Aspire 5100 acer • 3-1-5-300 Rolsen • VVX2000 DE`LONGHI • Archicad Graphisoft • Adj EP4000 023 Minolta • Whirlpool AMW 755 IXL 858775501911 en151 • 5991-3196EN Gauging Temperature Accuracy • GPF12DE TX-P42U10B TX-P42U10E panasonic •
