maverick
Posted: Mon Jan 16, 2006 9:13 am Post subject: Panasonic CD stereo system- error |
| I have a panasonic cd stereo system, model SA-AK500, and each time i try to turn it on F61 shows up on the display. What could be causing this and how can i solve the problem? Thanks for all assistance. |
Posted: Mon Jan 16, 2006 5:13 pm Post subject: |
| f61 is a protection code. it means theres is a fault with audio output ic, usually there is dc on one of the speaker output rails, replacing the audio output ic will usually cure this but check speakers and leads for shorts before reconnecting to the unit. |
Posted: Tue Jan 17, 2006 4:09 am Post subject: |
| I will try replacing the audio output ic but there are two of them. Should I replace both? |
maverick
Posted: Tue Jan 17, 2006 4:15 am Post subject: |
Posted: Tue Jan 17, 2006 5:22 pm Post subject: |
| no need to replace both. remove them one at a time and see if unit will then stay on. |
maverick
Posted: Tue Jan 17, 2006 7:48 pm Post subject: |
| gary wrote: |
I will try this. Thank you. |
maverick
Posted: Mon Jan 23, 2006 4:48 pm Post subject: |
| Thanks for the tip gary. The audio IC was indeed the problem. |
Posted: Mon Feb 19, 2007 6:20 pm Post subject: Panasonic CD stereo system - F61 error |
| I have a panasonic cd stereo system, model SA-AK500, and each time i try to turn it on F61 shows up on the display and then the stereo shuts off.. What could be causing this?? i seen on a earlier forum that someone suggested that a F61 error is a protection code. it means theres is a fault with audio output ic.. does anyone know what a "audio output ic" is and were i can order one? |
Posted: Tue Feb 20, 2007 9:30 am Post subject: |
| F61 IS THE ERROR CODE FOR A FAULT IN THE AMPLIFIER STAGE OF THE UNIT, THE MOST LIKELY CULPRIT IS THE AUDIO OUTPUT IC, WHICH IS A MULTI LEGGED DEVICE SCREWED TO A PIECE OF METAL USED TO COOL IT, IN PANASONICS ITS PREFIX WILL PROBABLY BE "RSN" BUT IT COULD BE "STK", MAKE A NOTE OF THE NUMBER AND SEARCH ON LINE, DONT FORGET TO CLEAN OFF THE OLD HEATSINK COMPOUND ON THE HEATSINK AND REPLACE WITH FRESH. |
guest01 Guest
Posted: Sun Feb 24, 2013 2:38 pm Post subject: panasonic stereo system error |
hello
I've panasonic SA-VK825D stereo system
first it wasn't executing orders neither from the main unit nor from the remote .. I've opened the main unit in order to try to fix this error .. I made a shortcut in the power board and burned an IC on it
now it gives me the error F61 when I turn it on and then turn off
how can I fix this problem and how can I replace this IC .. knowing that I've the service manual having most of the circuits diagrams and parts.
Thank you |
